87pathy
87pathy last won the day on April 27 2011
87pathy had the most liked content!
About 87pathy
  • Birthday 09/30/1974
    87 pathfinder, Axles: F/R full width HPD44 5.38:1 / Ford 9" 5.37:1 Suspension: F/R Ford radius arm with wristed radius arm 5.5" wild horse rock crawlers coils / Custom Triangulated 4 link 3.5" wild horse rock crawler coils. Traction aids: F/R detroit / spool Wheels & tires Chrome rock crawlers with 36x12.5x15 SS TSL's Extras: 3" body lift, bumpin stereo, custom bumpers, hand throttle, custom paint (rustoleum yellow) Comming soon: custom spare tire carier inside,
Contact Methods
  • Website URL
    http://autos.groups.yahoo.com/group/HOMEGROWN4X4/
  • ICQ
  • Yahoo
    ozzycones
    Puyallup Washington
  • Interests
    finshing, backpacking, shagging, building stuff
8,133 profile views
87pathy's Achievements
NPORA Old-Timer (5/5)
13
  1. Thats exactly what mine did when the fuel pump packed it in. have fun
  2. You can use the stock pathfinder steering box. No worries. Been running mine for 8 years on 38's
  3. ok, cool. you should be ok then. however, if you want to run any larger than a 33" tire, your not going to have enough gear.. example. to get back to stock ratio with 36" tires, you need to go to 5.38:1
  4. question, I assume your asking this to do a SAS. what tires you running?
  5. In addtion, with the old fords, quite often you saw a STOCK 9" and D44 combo of 3.5:1 and 3.55:1. this is .05 in actual ration difference, with what you are talking about is only . 06. (4.56-4.62)
  6. you guys are not correct. the difference is only. .98%. up to 1.5 % is acceptable. for example, Ford gears. Front Dana 44- 5.38, closest matching gear 5.43 (for the ford 9" in the rear). This has been done for YEARS. I used to run it in my rig. Run it.
  7. for doing sheet metal that would be fine. if your going to do any "fab work" you need a 220 machine, but don't get a stick welder if your doing sheet metal and just learning.. VERY difficult.
  8. called Ruff country and asked where the hell my heim joints are. that is all.
  9. you can put 4 quarts in these pigs with no issues. when i change my oil, it gets 4 quarts. when i have oil pressure i worry, cuase i never do.. the sending unit is bad. if your lifters were not tapping, don't worry about it. i bet its a sending unit with a loose wire.
  10. they are not even bolts, they are screws on the valve cover.. they come loose all the time, just snug them up.
  11. ordered new hiem joints through out, and new front suspension bushings.
  12. if your paying over 50 bucks for a front d30, your getting ripped off. i find them all day long for under 100. nobody wants them.
  13. oh, my missunderstanding. I though he was going to pull a manual tranny and install an auto. I'll shut up now.
