RWC5S2
Everything posted by RWC5S2
  1. What? Ju don like mi lites? The man at the trailer park said they were all the rage. I shopped all kind of brands and they are all 55watt so I figured why spend $90 for the same amount of light. Tell ya what....I shall paint over the Baja and put some decal on them. But, not a smiley face. I still have some pride left. With regard to the 33's rubbing, they do rub a little. Need to trim a little more of the inside plastic off. Kinda wierd though. They will rub on a small bump but not when I stuff the tires up to the back windows. Or maybe my screaming drowns out the rubbing. I do appreciate all the suggestions on how to spend more money. I shall be looking for a locker or at least an OEM limited slip. Will most likely do the Warn hubs on the front to ease the wear and improve MPG.
  2. Cool. Let me know when and where to send some money.
  3. Please count me in for a set of the 1" spacers. I can have a check in the mail when ever you can order.
  4. Nice pic's. Very nice area to wheel. Wish So Calif. had more of the trees and trails. Nice looking rig also.
  5. I see there are many more ways to spend money. Thanks to all for the info. Not too hot for a snorkle as then I would have to get it all wet and such......lol. The KMA bumper is $460 for plain, $480 for the receiver style like mine or the winch mount. To answer the oil change issue, yes it is a big pain. You gotta be real fast to get a funnel in there or spill oil all over the plates. I found a place that will drop the plate to change the oil for no extra charge as long as they are slow. I must admit that the black lights look pretty cool. I might entertain that option. Not too sure about a bigger roof rack as it might not fit in the garage. Will have to measure that option. The stereo is a dealer upgraded 5 disc unit. Being an old fart I can't hear worth a dang any way so no need for a bigger unit. The windows are already tinted so that was nice. I will add a pic of the underneath after this post. The bumper bolts into the existing 3 frame holes on each side with 1/2" grade 8 bolts. It is actually pretty stout. I did have to cut off that wierd looking extension that seems to serve no purpose. Can't believe how cheezy the OEM bumper was mounted. Nothing but plastic and a 3" wide chunk of sheet metal. The factory plastic bumper would have cost double the price of the KMA and only have gotten messed up again. I just might get a cold air intake unit. The current 13MPG sucks and I could use a boost.
  6. I welded the sliders rather than bolt. I used 2"x2"x1/4" angle stock to weld to the sub-frame. The slider braces then easily fit and were welded to the 2x2. Since the R-50 sub-frame does not extend down like the Jeep that was the only way. Made a nice installation and is incredibly strong. The tires are included in the overall lift height.
  7. Oops! I forgot to mention the full armor underneath from 4x4.com.
  8. Just had to share my toy, a 2003 R-50. I added the A/C lift and put BFG A/T 33x9.5 on steel rims. The rock sliders came from JCR Off Road. I ordered one for a Cherokee but called and they made it 6" longer to fit my rig. Nice folks. The bumper is from Kennesaw Mountain. I know, not the favorite around here but it works well. I figured the spare on the roof will work until I raise major bucks for a rear bumper with tire mount. I ended up with almost 6" of lift over stock and it goes places I most likely shouldn't. Guess I need those 1" aluminum strut spacers talked about in another forum and I will be maxed out, unless I opt for a Prado lift, which is very doubtful.
  9. Some brake systems make noise when the pads are getting worn down. This is to warn you of time to rep;ace.
  10. I am very interested in your 1" spacers. Hopefully you can get some made up? I shall be watching for any info.
  11. I ordered the bolts at the same time as the lift kit. Think they were another $20.00 and only needed 2, one per side. If you add any strut spacers you might need longer camber bolts but verify with the experts at NPORA. I want to add spacers to my rig but kinda fear messing up the CV joints/angles/etc.
  12. I did the AC lift on my 2003 Pathfinder and there was no need to do anything to the rear. Only the front and you do need the camber bolts.
  13. Actually, they look pretty good. You can see pic's under my post.......33's on my Pathfinder. Now, get back to your prunes and apple sauce. Plus, there is a McGyver marathon on tonight.
  14. I did the AC lift on my 2003 R-50 and put BFG 33x9.5x15 tires on my rig. Very minor trimming, mainly excess plastic. I did remove the rear mud flaps. I get some slight rubbing but it is only on inner plastic that I need to cut off. They look great, work fantastic except for deep sand and I ended up with over 5 inches of lift over all.
  15. Nice looking rig. Also, looks like a rather cold place for 4wheeling. Guess So. Calif has spoiled me.
  16. Be sure to check your tires to see if a slow leak develops. I had the same problem with pebbles and one tire began losing air. Easy fix but still a pain.
  17. I did my AC lift about 6 months ago and got at least 3" out of it without a strut spacer. It has not really sagged any noticeable amount yet. When I placed my order for the lift kit it took 8-9 days to arrive. I got the lifting coils, Rancho Struts and Bilstein Shocks. I have since gone to 33x9.5 BFG tires and my R-50 will go any where I want and most places I should not.
  18. Sorry, I forgot to mention that I did the AC lift also but without the strut spacers. Worked out great.
  19. I switched my 2003 R-50 to 15" steel with a 4" offset so I could run 33x9.5 tires. The rims came from 4wheelparts and were just plain $80.00 rims. No problems with any clearances. I got rid of the factory 16" spiffy rims.
  20. Per Kyle at Kennesaw they will be making the rear bumpers for the 1999-2004 Pathfinder in early January. Guess I will just have to spend another pile of bucks to finish of the ole R-50.
  21. What do you see as a problem with the mounting system.
  22. Before you go spending a ton on the TJM bumper you need to check out the one being made by Kennesaw Mountain Accessories. They just started production on a bumper to fit the 1999-2004 Pathfinder. I ordered one with just a receiver for $480.00. That price will also cover the "wincher" style that you can mount a winch on. There are a plethora of options to add if so desired.
  23. I saw them, called the guy and ordered one for my 2003 Pathfinder. They offer all kinds of options. I chose to just go with the receiver style. Will add my own lights for off-road/night time.
  24. No lift you can fit 30's easily. With a 2" AC lift I am running 33x9.5 BFG's. If you want a 10.5 tire you will have to stick with 31's to clear the wheel wells.
