PathA4
Everything posted by PathA4
when I opened up my wife's 04 SE, it wasn't obvious where the filters would go. then I saw the instructions that suggest cutting open the cooler unit. that's where I stopped and put everything back together. has anybody actually done this modification? the instructions are pretty vague and refer only to cutting out the shaded area.
etrailer.com for all your hitch needs. at least that's where I got our hidden hitch and the necessary connector hardware.
First Post, Hi All. Brake Disc Removal Q
PathA4 replied to PathA4's topic in 96-2004 R50 Pathfinders
After I did my wife's, I had some pulsing and a little noise, but as I bed the brakes in, the problem resolved. I wonder if I had some bearing grease on the rotors by accident. It wasn't anything like you said though... -
We've got Revo's on my wife's 04 SE and they've started to cup a little after about 15K miles. I've rotated them religiously, kept up with alignments, and just recently installed new Rancho RSX struts/shocks. We'll see if the problem resolves.
US Patent describing technology in Rancho RSX shocks/struts
PathA4 replied to PathA4's topic in The Garage
I guess I was too busy being impressed by the patent marking that I didn't notice the orientation marking right below it. -
Yeah, I think the cheapest patent application I ever prepared for an individual client was still more than $5000. One thing I just learned reading the shock absorber patent is that it will only work if the shock is oriented correctly. I don't remember seeing any Up/Down markings on the shock body and it didn't come with any install instructions. So when did you leave Charlotte? -
Got my Rancho RSX shocks yesterday and as I pulled them out of the box, I noticed US Patent 5992585 stamped on the shock body. Being a patent attorney, I pulled the patent to see what it looked like. Thought I'd share it with you. I believe this technology is incorporated on the Monroe Reflex shocks/struts as well. Abstract A shock absorber has a base valve assembly which includes a compression valve assembly and an acceleration valve assembly. The compression valve assembly controls a fluid path through the base assembly to provide a firm damping characteristic for the shock absorber during low acceleration movement. The acceleration valve assembly controls a second fluid path through the base assembly to provide a soft damping characteristic for the shock when the shock absorber experiences acceleration beyond a specified amount. US Patent Number 5992585
Get ExtractNow from www.download.com As for the spindle nut tool, I can't give specific dimensions. I just know it's the one listed in most catalogs for Isuzu Rodeo/Honda Passport vehicles. Also, i know some have purchased the ford 4-prong spindle tool and ground down 2 of the prongs to make it a 2-prong tool. -
Here you go: FSMs -
FWIW, on my wife's 04 SE, the cross bars do not come out by lifting them up after completely removing the knobs. The little threaded plates referred to above are retained in small slots within the cross bar end caps. These slots ride in the channels of the left and right longitudinal bars. So, I removed the rear end caps. These have plastic covers that snap off in an upward direction (away from the ground). Once the cover is off, you can access two torx screws. A third torx screw resides in the channel of the longitudinal bars where they meet the end cap. With all three torx screws out loose, the end cap separates from the roof and from the longitudinal bar. With both end caps off, the loosened cross bars slide out the back.
a-ok here
front wheel bearings by feel or special tools?
PathA4 replied to sigtauenus's topic in 96-2004 R50 Pathfinders
Here's that socket for $13 from summit racing. Summit Racing Link I had to grind the square pegs a tiny bit to fit flush in the round holes, but otherwise it's a perfect fit. -
So I noticed the Nero doesn't come in the OE 255/65-16 size. If you all are going with larger sizes, do you just deal with the wrong speedo readings. What sizes are you increasing to?
Sugar Sugar - The Archies (US) Bad Moon Rising - CCR (UK)
oh and btw, i installed a hidden hitch from e-trailer.com and really like the curved tubular look over some of the square right-angle uhaul trailers i've seen on several pathys. i purchased and installed the wiring harness from them too. they also sell transmission coolers too. take a glance when you have a chance.
Looks like the Hayden built cooler I just bought at advance auto parts. I think I paid about $60. I bought an extra transmission cooler hose just to make sure I had enough length. I haven't installed mine yet. Maybe this weekend. Does that one come with the mounting hardware and clamps?
I know on our 04 SE, there is already a dedicated trailer power line running to the fuse box. If you didn't get the trailer option, the fuse holder is empty, but the wiring is still there. I wonder what year they incorporated this.
i'd never wish cancer on anybody
we're in cary. i assume uncc is nc-charlotte? my wife's parents and older sister are in charlotte. all of us are fairly new to the state. < 3 years
we just had our law firm picnic and we were talking about all the exams we've taken in our lives. i totally forgot about the EIT. i took it and passed the first time. my undergrad grades were pretty good. undergrad gpa was about 3.5. the only exam I took twice in my life was the LSAT. not sure why, but I just didn't do what I expected of myself on that one. second try was only about 1 or 2 points higher. i'm sure you'll do better the next go around
Yeah, sorry. I actually pondered this for a few seconds. Were you able to salvage the broken piece? Hi-Temp Epoxy?? Permatex (usually found at auto part stores) offers all kinds of adhesives and sealants, including a radiator repair (although this is usually to plug small holes).
Picked up in person at the dealer yesterday. -
Excellent photos. I just bought the following parts from summit in anticipation of doing the bearings. Should be a messy weekend. Thanks for all your help! RED-80402 CV-2EP GREASE 14OZ A Shipped on 06/16/06 $8.50 1 $8.50 SUM-W1218 BEARING PACKER A Shipped on 06/16/06 $3.95 1 $3.95 SUM-W54204 PRO PISTOL GRIP GREASE GUN A Shipped on 06/16/06 $9.95 1 $9.95 SUM-W83007 4WD SPINDLE NUT WRENCH ISUZU A Shipped on 06/16/06 $12.95 1 $12.95 -
Thank you kindly sir!! -
What material are those spacers made from?
