Everything posted by BigMike
Definitely following this with anticipation.
Interesting..So to special order a board I would have to talk direct to Nistune? I'm going to be swapping a VG33ER here soon and was looking at doing a diy Megasquirt later down the road but this catches my interest to get it running up sooner than later.
Not on my end. On the invoice the value was listed as 198.00, I assume the rest is shipping and related costs.
Got mine in. Came by a shipping company called TNT. Gonna wait for it to cool down before I put it in.
I would be interested in a front and rear for my 94 if they offer for othe years.
Hardbody/Pathfinder Aftermarket Headlights
BigMike replied to ebayfish's topic in 90-95 WD21 Pathfinders
I found these a while back. Have been considering them myself. http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=92027'> http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=92027 http://www.hidprojectors.com/product.php?type=34&multi=0'> http://www.hidprojectors.com/product.php?type=34&multi=0 -
well one of the reason i was looking at the rubber was ride, i know its an 4x4 but i figured it helped the ride a bit plus i had already paid for them. that and the polys are squeeky. but the polys wont degrade like the rubbers to salt and weather.
i got my new UCAs today and with them came new poly bushings, i wasnt planning on using the bushings that came with them cause i had a set of Moog replacement bushings i was going to put in my stock UCAs befor i decided to lift it. the Moog bushings are basically OEM rubber and are tight as hell to try and put in but the polys go in easier. i wanted to try and keep a OEM ride some and not make it so stiff but the moog bushings are different in shape too. shorter and different. what im wondering is do yall think that there will be and adverse affects cause of the shape how it is? im guessing its going to spread out some when compressed but there like 50% less surface area thats going to come in contact. i preffere the idea of the tighter fit the moogs offer but im just curious to know what yall think. btw the polys are on the left moog on the right.
thats a very very lucky man
i myself am a massing the parts i need, im going to redo the whole front end. ive got the UCA bushings and BJs, all the wheel bearings and seals, new manual warn hubs, new rotors cause mine are gouged out and screwed, compression rod bushings. all i need are the lower BJs and LCA bushings. then i can dive into the project of getting it done.
yep they are loud, mine has a flowmaster on it and sounds sweet when i rev it up. ill try to get a recording of it one of these days.
god your silly thats the MP3 player DUR
i wish i had money cause those are awsome
prolly just for compressed air to force it out
hah i did the same with a socket. very fun aint it?
one thing that bothers me is the claim about all the interior work with no shots of the interior. you cant see what kinda workmanship they put in the vehical. the finer detail is what i like too see. these are all claims that they gotta back up but dont. i would be surprised if they do sell it.
is the blue one a Spec-V? those suckers are sweet. ive been kinda wanting to get one. but i cant deside. a black Spec-V or a 68-73 Datsun 510.
from my understanding you need the headlight mounts (those things in my link above) so you can mount them on your vehical. the reason is cause those hella lights are basically the the same except they are not a sealed beam. sealed beam being you have to replace the entire light and lens and housing combo to put in a new one. the hella ones are made to be perminant and just replacing the bulb not the entire assembly IE lens and housing. the mount allowed the you to replace the sealed beam headlight with out having to reaim the sucker every time it went out. the hellas are a direct replacement for the sealed beam that would be why you need the mounts for you truck.
well you need the headlight mouinting hardware. headlight mounts
all first gen pathfinders came with that notched headlight. some hardbodies did but they changed that to the sealed beam type. you can convert to those hella lights but you will need hardbody headlight bucket/housings and the associated grille and corner markers. the hardbody and pathfinder use the same radiator support and their parts are interchangable. this is where i got the idea from. i plan to do it as soon as i have sufficient funds. http://www.4x4parts.com/ubbthreads/showfla...rev=#Post369777
do you have a link for this kit? ive been wanting about upgrading my lights, i might have to look into this. otherwise im just gonna go ahead and start from scratch to converting to E-code lighting with H4 bulbs, heavy gauge wire realays and the hardbody grille. i do pleanty of night driving and i hate the dismal lighting i have. my moms sentra low beam setting covers nearly the same area as my high beam setting.
the ammonia medthod is one of the easiest ive tried. it sofents the polyester and peals right off. a shop is prolly gonna charge any where from 20 to 50 bucks to take it off. if you got nothing else to do on a saturday you could save your self some money and do it your self. heres a site just for tinting http://www.tintdude.com/ but lurker pretty much showed the easiest way.
moog sells bushing for the whole truck if i remember, they use some sort of hard rubber plastic combination. EDIT: infact heres their list, the k#### is their part number followed by the year and how many their are needed per vehical MOOG Upper Control Arm Bushing/Kit FRONT SUSP K9209 87-96 2 Lower Control Arm Bushing/Kit FRONT SUSP K9546 87-96 2 Sway Bar Link/Kit REAR SUSP UPPER & LOWER K90038 87-95 2 Sway Bar Link/Kit FRONT SUSP K9222 87-95 2 Sway Bar Frame Bushing/Kit FRONT SUSP K9582 88-95 1 Sway Bar Frame Bushing/Kit REAR SUSP K9969 87-95 1 Strut Rod Bushing/Kit FRONT SUSP K9515 87-96 1 Track Arm Bushing/Kit REAR SUSP K90037 87-95 2
i guess it all depends on how much money you are willing to spend. i see some waggy d44s put on, mostly leafs cause of ease, and a few coil setup datz510 has a early bronco front axle and coil setup that is very nice. never seen any rockwells under pathys yet. as for power, 350s. cause there are so many, can be had cheap and lots and lots of aftermarket. but in the end its money and how much that does the dealing,
so any one know where to get replacement boots for the transfercases?
