ac92pathfinder
Everything posted by ac92pathfinder
  1. i have a 95 nissan pathfinder the antenna not goin all the way up like it use to. for awhile i used wd40 but the doesnt last along time. anyone else has any ideas what i can use to make it go all the way up?
  2. i had this problem on my 87 jeep grand wagoneer. the oil was dripping on the cross over pipe and what i did for now is get a thin peice of metal sheet and bolt it to the transmission plate and bend it over the cross pipe but angle it down to where it wont drip over the cross pipe and that will save you a fire hazard and the burning smell.
  3. why are some people have problems with there 31's hitting the fender?
  4. ya i'll just get it re balanced and go from there thanks
  5. im gonna go to walmart and get some chalk but i did lower the tire down to 33psi on all 4 and once i did that one of my front tire is wobbly. thanks i'll do the chalk test.
  6. i have the legos and running 31x10.50 r 15 these are wider then the other 31's that it came with
  7. common post what can i do to stop the tire wear in the middle i have 31's its always on the rear i run about 34 or 35lbs in my tires.
  8. nope never been there but its been serviced there from the previous owner. im not too worried about it right now. i kinda gave up. i saw wires under the seat thats cut one was for the horn.
  9. same here i got em at az they fit great its there brand too its like 24.99
  10. also when i started my car up to pump the brakes to adjust the rears i noticed the rev went up and down alittle.
  11. i ordered the brakes and will be in by 4pm tomorrow edit that i went to autozone they had my pads for the same price for what i ordered from kragen the 18.99 special. i bought the duralast pads which i been useing for awhile but my from pads a valucraft which works soft. they both work good i was ust broke at the time to buy valucraft. now my brakes works good just need to top off the resivor keep forgeting to top it off been 1/2 low for a month.
  12. right now so far so good it aint grinding yet. one more day and i'll have my sisters car to do my route. but i do have to use the pathy friday im crossing my fingers.
  13. i pulled the wheels off on the rears. they have enough left till friday. sucks hanging on to one job that bearly gets you by.
  14. i still got my explorer to use i'll look at the brakes after work.
  15. well you figure 40 or 50 miles a day till friday. cause i need it for my paper route. im gonna use it tomorrow im also gonna pull the rear wheels off and check em.
  16. 95 nissan pathfinder when i step on the brakes i can hear the indicater from the pads hitting on the rotors on the rear. was wondering aprox how long they would last before they grinding? i can get the pads friday or saturday. this has happened for 2 days. im hopeing it can hold till then. thanks ps there pads btw
  17. right now its so much better alot smoother thanks guys
  18. will this also help my gas mileage? should i check the fluid level again after i drive it from filling it up?
  19. btw the fluid came out kinda dark grey with some swirls im guessing it may be some water. but the last part id say 1/2 a qt came out brown clear.
  20. done i replaced it with lucas gear oil. so i didnt have to add any additives it made so lsd also. i took it down the road for a drive found a dirt area made all kinds of turn forwards and backwards no loud noises just alittle which is normal. but its also not as long as it was before too, the lsd kicking in. thanks guys for the replies. as for the tire its on the rear that was rearing out its from the lsd kicking in when im makeing turns cause i can hear it grabbing. i also got to fix the passenger rear tire that had a screw in it for the longest time. what a bitch it was getting it out. so now its plugged.
  21. i was gonna do it myself. just by the oil there is what i ment. im just thinking of getting the supertech oil for now till i can afford the good stuff. can i just buy one lucas brand and the other 2 supertech along with the additive?
  22. aint that bad i went right when the opened at 7am after i got off of work. its a small walmart anyway. i went to kragens they have vavoline for 5.69. i wanna use lucas can i buy 1 lucas and 2 vavoline? reason is i lost my other job and dont have much to spend. im just debating of just toping it off right now. thanks
  23. walmart has the super tech says it can be topped off for lsd. will this work or do i still need the adjative?
  24. ya i was talking to kingman too and he also said its either low or the oil needs to be changed. i figure i minus well do it just change it. anyone recommend a brand? im gonna head over to walmart tomorrow and see what they got. thanks mypath for the reply.
