ac92pathfinder
Everything posted by ac92pathfinder
  1. i see some people on here put there spare tire on there roof of the car and i was wondering what u guys used to hold it down. i wanna start putting mine up there cause i use the hatch alot and tie tire gets in my way. im probably guessing u guys use straps to hold it.
  2. works good except the front speakers dont work might be another wire for them cause it was working. when i had the infiniety chrysler radio in it better then nothing lol
  3. ok so i was gonna go buy a tester i started the car up and it worked out of nowhere thanks
  4. they had an fm box do i need that i took it out i guess its for the antenns i just plugs the main wire for the antenna into the radio and took out the fm box. but the fm box had a red wire with a fuse on it.
  5. hi i hooked everything up and nothing from the radio. i checked all the fuses
  6. gonna have to throw the 2 front ones in the back cause they match my 2 back tires are the same size but 2 different brands. there the same size all the way around.
  7. im tryin to hook up a new radio in my car and of course someone cut off the stock radio plug. can anyone tell me or direct me on finding the color code wires whats what before i start blowing fuses.
  8. doesnt light up or u cant use the options. the onlything that works is the hot and cold and the fan. i cant switch it to defroster or any other of the vent settings. i checked al fuses and there good. could it be the controls?
  9. my front tire. i inspectted the tire didnt see any flat spots. maybe a broken belt in the tire?
  10. just hisses might be the pump i see no leaks. i smell gas. only does it when it runs.
  11. the back of the car where the gas tank is. I do smell gas around the back of the car but i dont see anything leaking and when i remove the gas cap it releases pressure. im not sure whats going on. any ideas?
  12. came on this morning while i was warming up the car this morning. both just came on for a quick second then off. probably nothing drove fine for a few hours this morning. kinda messed with the idle at the same time just for a quick second. anyone ever had this happen? probably nothing. thanks
  13. just curious. im looking on getting a owners manual soon
  14. my consil not all there going to junk yard today to get one. my other question was whats the switch for the shocks for? what does it do?
  15. what does the voltage regulator look like so i dont pull the wrong one by accident
  16. i think the full size covers the license plate kinda? wish i had another place to put it i use my hatch alot.
  17. when i bought it the light was on so it was low i just added some in there 3 days ago then i had to add some before work this morning. i'll have it looks at. dont want to take chances driving it then it gives out cause i use it for my job everyday. thanks for the replies
  18. does this mean its the master cyl? if so is it rebuildable?
  19. i take that back. Problems with your fuel and temp gauges are common with the 95 and older trucks. On the back of your cluster is a small box with some wires coming out of it going to different points on the cluster. This is a voltage regulator for the gauges and it is known to fail. I got a new one at my local dealer for about $25 and it took about a total of 2 min to replace. (from MrReverse) is this located behind the instrument cluster do i have to remove that? also my heater controls dont work the hot and cold does along with the fan but i can get the controls like the defrost and sround that area to work also they dont light up. just my speedometer area. i checked for blow fuses i didnt see any.
  20. i didnt see it in there. also i have brake fluid leaking between the master and booster is this a master cyl problem? if so is it rebuildable? thanks
  21. i have a 92 pathfinder xe 3.0 someone by passed the plug thaty goes into the temp switch to the battery instead i plugged it into the switch but doesnt work along with the gas gauge. if i leave it on the battery i get back and fourth readings like one time it said i was over heating and it would sit on cold too. what can i do to fix this? thanks
