blackspawn
Everything posted by blackspawn
  1. 207,000 no rebuild...and running and cranky!!!!
  2. Seafoam my engine, had a loud lifter ticking. NOT anymore!!! I love SEAFOAM!
  3. Thanks for the info!!!! I'm on the HUNT!
  4. Ok, I'm hearing the HD auto transmission...My question is where is this HD auto transmission coming out of so I can get one for a spare tranny?
  5. Got the same problem, guess I better try Seafoam...
  6. My truck did that once, and I found the wires on the positive side of the battery was kinda loose. One of them was feeding one side of the headlights. I have a 90 Pathy if that helps.
  7. Took out my headlight switch and cleaned out the contacts so it would work properly...
  8. I'm going the buy a new one route,I priced one at AutoZone for $56. Thanks,bro.
  9. I have the exact same problem, driver side high beam not working. This problem just started a couple weeks ago. I can move the headlight switch toggle forward before its in the locked hi beam position and both light are on. I think my problem is a bad headlight switch. What do you guys think?
  10. Wow, thanks guys.. I see this is not a 2-3 hour job.YEAH!!!
  11. The bottom of the truck is always wet also it fall on the exhaust pipe causing it to smoke.
  12. I'm trying to keep this thing till it die,but I'm at that age that if its giving me too much trouble then I get rid of it.
  13. I've check everywhere on this site to change out my oil pan gasket. Need to know if I need to take apart the whole frontend just to change a oil pan gasket? I love this rig but I'm very close to @!*% canning it. Simple stuff takes too long on this engine ie..oil pan gasket,valve cover gasket just ridicules.
  14. Thanks guys,I'm guessing with the tire off I'll have to lift up on the lower arm control to take off some of the tension to loosing that big bolt huh?
  15. What did you use to get that big nut off on the end? Regular socket and wrench or impact gun?
  16. After using regular rubber bushings and putting the truck back together my polyurethane bushings came in,there are 4 bushings each sides for the UCA's, 2 bushings for the swaybar and 4 bushings each side for endlinks for swaybar and I beleive there are 4 bushings each side for the tensioner/strut rod. I chicken out on changing the lower arm bushing due to special tools and taking torsion bars off!
