All Activity
- Today
Yeah, that's not good. Could be the key, though I'd be surprised if it just freewheeled with that busted. I've also heard of VG30 cranks breaking between the timing sprocket and the balancer. Hopefully it's not that. Grab the pulleys and see if the whole deal just comes off. I've heard of people welding and grinding a damaged keyway, or welding in the key, or using JB weld or Loctite and trusting the crank bolt's clamping force to do the rest. I don't remember if any of these methods worked, but I do remember seeing a few mentions of repeat failures. These may have been from people installing a new key in a wallered keyway without doing anything to stabilize it, though. And yeah, if the crank turns out to be buggered, might as well get an upgrade out of the job. The 3.3 crank snout is bigger. This is a good thing, but also a problem--it's why you need to run the donor's belts/accessories, or get an adapter to run the V belts, because the 3.0 balancer won't fit over it.
That sucks, and is the kinda "freak" occurrence that would make me wanna swap in the VG33 engine, but that comes with it's own cans of worms, too! (Go for it if you can easily get a replacement engine!) And you've probably already seen this thread?
- Yesterday
Sorry, cross posting for more visibility: Currently sitting on the side of the highway with my 87 waiting for a tow truck. First the power steering cut out which prompted me to pull over. After I pulled over I noticed the temp was getting really hot. With the engine still running none of the accessory belts or pullies were spinning, I couldn't see if any were broken. Does this sound like the about key issue? Timing still seems ok but I haven't started the truck since pulling over. What are options for fixing if this turns out to be the issue? Upgrades available for a stronger snout key? Also wondering on the feasibility of a VG33 upgrade instead of rebuilding this guy. It's a bummer because this engine was otherwise in amazing shape and running beautifully, probably better than my newer cars. Still has the cylinder crosshatching.
02 4wd Mechanic can't find size for front u-joints
adamzan replied to LoveMy02's topic in The Garage
Some of the aftermarket u joint kits come with snap rings of different sizes/thickness. Otherwise I have filed them down to fit, not saying it's the right thing but it worked.. -
Sudden loss of power has me thinking timing. Is yours the 3.3 or the 3.5? (Not sure when the 3.5 started down under.) The 3.3 has a rubber timing belt. IIRC they run like crap a tooth out, don't run two teeth out, and will eat the valves somewhere past that. The 3.3 is a little less interference than the 3.0, so you've got a decent chance of the valves being OK, but I would not push that luck by starting it again before confirming that the belt hasn't skipped a tooth at the crank. Roll the engine to TDC, pull the covers, count teeth between the dimples. 40 between cams, 43 cam to crank. If it's the 3.5, I've got nothing. My dad's Tundra jumped time a while ago because a mouse found its way in behind the timing cover. The engine got lucky, just needed a wipedown and a new belt. The mouse was not as lucky.
- Last week
We have travelled from Adelaide to Brisbane to visit our son. We plan to return via South East coast. So far, the car drove perfectly. Driving around Brisbane was fine too. Yesterday (Saturday) went for a drive to see grandkids playing soccer. Returned home. While the engine was still hot, started the car as usual. Still in Park gear. Turned on the A/C. The car engine shook like a wet dog then stopped. Turned off the A/C. Restarted the car. Started Ok. Put gear in Drive. Very reluctant to go up the drive. Managed to get on to road but lost power. Parked by the side of the road. Checked engine oil, gearbox oil, coolant level all OK. Called RAA. Their Road Service guy arrived. He started the car. Turned it off. Said to me, "Your engine is very sick". Then he asked me to contact the nearby mechanic on Monday morning to make a booking, and call RAA back for a tow truck. HE did nothing else! No diagnostics using any code readers. Please help. What can I do in the meanwhile. I have purchased new platinum plugs last afternoon but it is raining at the moment (Sunday morning).
atomic clock
FuryLenon331 joined the community
Rebuilt transmission, won't go in reverse
Slartibartfast replied to 98dreamer's topic in 96-2004 R50 Pathfinders
Sounds like a question for the rebuilder.- 1 reply
- 1
I broke it, had it rebuilt, now it won't go in reverse. Somebody he'p meh? 98 LE 4WD. 4E1R01A trans. Sent from my SM-S906U using Tapatalk
98dreamer started following Rebuilt transmission, won't go in reverse
Diagnosing A/C Compressor Clutch not engaging, what next?
Edzaz18 replied to commodorehat's topic in 96-2004 R50 Pathfinders
Hey guys im new to this forum,Ive got a 88 pathy and the ac isnt workinh currently i havent had any luck finding the relay and wanted to see if you guys know the location of it by chance -
Edzaz18 joined the community
Most stubborn cylinder 1 Misfire/rough idle ever?
CamperDan replied to Smith's topic in 96-2004 R50 Pathfinders
Yeah used O.E.M junkyard parts are better than crappy new aftermarket parts any day. My ALTERNATOR recently gave up the ghost and I replaced it with a used O.E.M one from the junkyard and all is well again. Now at least when he swaps the fuel injectors around and the misfire moves he will know what to do from there. The con is having to tear things down again. Chris. -
Ok so that rules out the MAF then. Chris. -
Slartibartfast replied to Smith's topic in 96-2004 R50 Pathfinders
Yeah, I hear you on not wanting to throw expensive parts at it on a hunch. I don't know how good aftermarket VQ injectors are/aren't, but I remember Cuong Nguyen had a hell of a runaround with cheap injectors causing problems on his VG. I think he ended up getting a set of OE ones from the wreckers. Being a cheapskate myself, I'd probably try and swap the injectors from hole to hole before buying new ones, but I also understand not wanting to have to take it apart a third time if it turns out the injector is the problem. I would be tempted to also check under the valve cover while it's torn down, but that's mostly because I just opened up a misfiring Dodge where the roller decided it was done and ate the cam lobe. I haven't heard of a VQ doing that either, and I imagine the noise would've tipped you off if yours somehow had. Hopefully it ends up being something simple. Good luck! -
Smith replied to Smith's topic in 96-2004 R50 Pathfinders
I'm with you in that I've never really come across head gasket issues on a VQ, and I've had a few myself with higher mileage. Definitely not losing coolant, but I agree that it might be worth doing a leakdown at some point. I don't remember specifics on when I pulled that plug but I do remember thinking that it was an unburnt fuel situation. I'm finding very strong spark every time I test, which is frustrating. Figured that could also indicate that the injector was dumping too much fuel into that hole, which led to the pulling and cleaning of those. I did not swap that injector to a different location when putting them back in, and now I'm rather regretting that decision. Also no flow test, but from what I saw the flow shouldn't have been TOO far off from the rest. If I go back in that deep, I'm probably just going to end up replacing all 6 injectors this time around. Speaking of which, how much trust should I put into aftermarket injectors? It's hard to stomach spending OEM money on something that may not even be needed, ya know? What I'm seeing come out of the exhaust is definitely fuel and not oil. I'm all too familiar with the sights and smells of both. As far as the power valves go, I'd like to believe I would have spotted an issue there when I had the intake apart but I didn't check those specifically and I'm far from perfect. I'm thinking at this point my next steps might need to be leakdown, then pull the intake back off to check those and swap out injectors just to eliminate some of the more pain-in-the-ass possibilities. Thanks for the help! -
Thanks for the response! I also somehow completely forgot that I tested out swapping the MAF a while back and that didn't fix the issue either. For good measure, I checked on my scan tool and am getting reads of around 3.6gs so should be good there. Haven't had a chance to give the video a watch but will do so after work, so thank you for linking that. -
The MAF is a good thought, and an easy one to check if you've got a half-decent scanner. Could explain the hard starting, too. That said, I wouldn't expect it to only cause problems on one cylinder. The service manual offers a little troubleshooting for misfire codes. Might be worth a read. Looks like you've tried most of what they suggest, though. I would follow the compression test with a leakdown test. When the head gasket let go on my neighbor's Toyota, the compression still tested fine, but when I applied shop air to #4, it bubbled out of the radiator. (I didn't have a leakdown tester at the time, so I stripped the compression tester down to just the hose, and stuck the air nozzle in the end.) It's probably not the head gasket--I don't remember anyone else on here having a head gasket let go on a VQ, and I imagine you would've mentioned if it was losing coolant--but it's still worth ruling out. When you replaced the plugs, did #1 stand out from the others? Color, deposits? Might give a clue if it's a mixture issue. When you installed the injectors, did they all go back in the same holes they came from? And did you flow-test them after cleaning them? If #1 has its original injector, untested, I would not rule it completely out yet. Are you sure what you're seeing in the exhaust is fuel? My dad's '03 burned an alarming amount of oil, especially on warm starts, though I don't remember it throwing misfire codes. Have you checked your your power valve screws? Long shot, but if one of the butterfly plates fell in, I can imagine it getting stuck in front of an intake valve or something. -
JOHN50 joined the community
If your scan tool reads live data take a look at your Mas airflow sensor and make sure it's reading at least 3.5gs as I had a very similar issue and just like your self once the engine was warmed up when ever I came to a stop at a red light I would experience a bit of a stumbling idle. Turned out to be a bad Mas airflow sensor that was under reporting data 2.97gs to be exact. Oh and I have a video you can checkout on said issue as well. Here's a link. Chris. -
Smith started following Most stubborn cylinder 1 Misfire/rough idle ever?
Ok the title may be a bit dramatic, but I definitely need help. I've been around here for years since I got my first R50, but I honestly don't remember if I have ever posted. I have mostly just read and absorbed until I've come across an issue that I can't seem to figure out. Thought I might see if anyone has an ideas for me that I haven't tried already. I'm on my second R50 now, which is a 2003 with the VQ35 and about 135k miles. A while back I started feeling a little roughness in the idle but only once the engine was fully up to temp and at its lowest idle (in gear). At the time there were no codes aside from one regarding the key chip not being recognized some of the time (I forget the acronym) because I'm using some cheap aftermarket key. Regardless, I figured that shouldn't have any effect on anything once the engine is running. Time goes on, the roughness in the idle gets a bit worse and I finally pull a Cylinder 1 Misfire code (probably P0301 but I'll have to confirm later). Started with replacing plugs then swapping coils around to see if it followed, it didn't. Compression test showed within a few percent of the other 5 cylinders' PSI. Injectors were all pulled, tested, and cleaned on a little homemade rig I made out of a 12v battery, some spare hose, and a can of carb clean. Fresh o-rings and those went back in. Aside from maybe running slightly better overall, the same idle issue and Cyl 1 Misfire code remains. No apparent vacuum leaks, and the one leak I did find with the "spray carb cleaner around the engine bay while running" test was a huge crack in the underside of the intake hose/pipe which has since been replaced and apparently wasn't the problem, despite my excitement in thinking I had found the issue. One other likely important detail that I forgot about until this point in the post is that sometimes I'll have to crank the starter for 3-5 seconds to get it to start, and when that happens it seems to dump quite a bit of fuel out the exhaust immediately after start. I'm assuming this is fuel that is being passed through Cyl 1 without being ignited while cranking. This hard start also seems to only happen if the engine is warm but has been shut off for greater than a couple minutes. If it's cold or was just shut off, it usually starts just fine. Any tips or help would be massively appreciated, as this has been keeping me up at night quite a bit. I'm usually fairly decent at diagnosing things like this but apparently I'm missing something. I know there is a ton of experience rolling around in these forums, so I'm hoping one of you knows exactly what's going on so I can feel dumb and have a smooth idle again.
jlp joined the community
93 Nissan Terrano R3M TD27 Auto Trans Service
Slartibartfast replied to Drifter2090's topic in 90-95 WD21 Pathfinders
A friend and I did that on his Blazer. Got a bucket with measurements on it and poured in the same amount that came out each time. It would've worked better if we'd kept better track of the level in the bucket between rounds, but we got there in the end, and we didn't overfill it like I did mine. I did a bunch of work to the truck right after I got it, including the trans fluid, so I never really got a baseline for how it shifted before. After the flush, it shifts pretty well, apart from a lazy 1>2 shift under load. It hasn't gotten worse over the last 26k miles, and the transmission is still alive at 257k miles, so I'm not complaining. While you're in there, consider adding an external cooler, especially if you wheel or tow (the hotter the fluid, the faster it degrades). I also plumbed in a Magnefine external filter while I was in there. I don't know that it's doing much, but there was a little metallic shimmer in the old fluid, so I figured adding an actual filter was a good idea. -
Transfer Case Module replacement
pathy200086 replied to pathy200086's topic in 96-2004 R50 Pathfinders
just thought I would let you know I ended up finding Transfer Case Module with the same part number as mine for $189 a lot better then paying $2000 from Nissan,thanks are bunch for your help Slartibartfast hopefully it's just plug and play and no reprogramming needed. -
Definitely. With the enlisting of the old man we’ll get it done.
