Moving To New Servers!
Members interested in helping test the new NPORA server platform, please contact RedPath88 via PM or email for further information.
Thank you,
Low to no Oil Pressure
  • Please log in to reply
7 replies to this topic
#1 OFFLINE   Pathy87
Pathy87
  • Members
  • Pip
  • 12 posts
  • Local time: 05:56 AM
  • Country:
  • Model:SE
  • Year:1987
Posted 08 August 2017 - 12:33 PM
Hi there, I have an 87 3.0 pathy with 212,000 miles on her. When I start it up, oil pressure is great, as the engine heats up, it drops lower and lower. Once at running temp, the oil pressure is at 0 and the oil light comes on. 5 days ago I changed the oil and filter, as well as a new sending unit put in (old one shorted out and was maxing out the oil pressure gauge).
When its low, I don't hear knocking or anything, performance wise nothing changes. My pathy is running very rich right now, but not so rich that it thinned out the oil that quick.
Rock auto has a cheap sending unit, and an expensive one, I tried the expensive one first, that did the same thing until a bare wire touched metal then shorted out the sending unit.
This time I bought the cheap sending unit.
Should I run thicker oil? Anything else I should look for? During my next oil change, should I have the filter and oil inspected for excess metal? I figure this old dog is just tired and about to die.
#2 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 887 posts
  • Country:
  • Model:SE
  • Year:1992
Posted 08 August 2017 - 02:37 PM
Verify the actual oil pressure. Harbor freight has an oil pressure test kit for pretty cheap. Make sure there is actually a problem before you spend more time and money chasing this.
#3 OFFLINE   Slartibartfast
Slartibartfast
  • Members
  • PipPipPipPipPip
  • 4,475 posts
  • Local time: 04:56 AM
  • Country:
  • Model:SE
  • Year:1993
Posted 08 August 2017 - 06:19 PM
+1 for double checking, but if both the oil pressure gauge and the idiot light (I'm assuming the sensors are separate) indicate a problem, I'm inclined to believe them.
Was it doing this before you changed the oil and filter? And did it continue doing this immediately after, or do alright for a while and then develop the issue all over again?
#4 OFFLINE   adamzan
adamzan
    Hi
  • Members
  • PipPipPipPipPip
  • 17,586 posts
  • Local time: 07:56 AM
  • Country:
  • Model:SE
  • Year:1994
Posted 09 August 2017 - 06:52 AM
I would double check the pressure. If it really had no oil pressure the top end would be ticking like crazy. Could be a worn oil pump, worn bearings, or just a ****** sending unit. I believe it is the same unit for the gauge and the light.
#5 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 887 posts
  • Country:
  • Model:SE
  • Year:1992
Posted 09 August 2017 - 08:05 AM
https://m.harborfrei...-kit-62621.html
There you go. We had our 150kw mobile generator at work that was showing low oil pressure. I told the guy working on it to verify the problem and bought this kit to check it. Went cheap because it will probably be the only time we use it. As suspected, the actual pressure was fine, but one of the wires on the back of the gauge was loose, tightened it and everything was back to normal. Point being verify the problem, and the kit is good quality for the price.
#6 OFFLINE   Pathy87
Pathy87
  • Topic Starter
  • Members
  • Pip
  • 12 posts
  • Country:
  • Model:SE
  • Year:1987
Posted 09 August 2017 - 08:52 AM
Thank you all for your suggestions! I will purchase that kit and see what I find. I sure hope its just a faulty sending unit or loose wire.
To AdamZan : When I first start the truck in the morning it has ticking for the first 3 solid seconds or so until the oil gets slung up to where it needs to be, after that its fine.
To answer SLARTIBARTFAST :
When I bought the rig the sending unit didn't work at all. The pressure displayed 0 but no oil light was illuminated. (odd)
I then purchased a $40 sending unit, put that in, showed 60psi until it reached operating temperature then it would drop to 0 and idle and about 10-15psi while driving. A wire came out of the sending unit plug and touched the frame, which then made the sending unit display 120psi. (again, no oil light illuminated). I drove it like that for a year or so.
I finally bought another sending unit, eliminated the sending unit plug (made my own connection and soldered it) The oil pressure reads 60psi until it warms up and then drops to 0 at idle (oil light illuminates now when at 0), and shows maybe 15psi while driving after it has reached operating temperature.
I'll buy that testing kit and update you guys with the results!
Thanks again!
#7 OFFLINE   adamzan
adamzan
    Hi
  • Members
  • PipPipPipPipPip
  • 17,586 posts
  • Country:
  • Model:SE
  • Year:1994
Posted 09 August 2017 - 03:39 PM
Yeah, that is kind of normal as they age if the oil hasn't been changed religiously. Not a big deal. Mine does it every now and then.
#8 OFFLINE   Slartibartfast
Slartibartfast
  • Members
  • PipPipPipPipPip
  • 4,475 posts
  • Country:
  • Model:SE
  • Year:1993
Posted 10 August 2017 - 03:26 PM
+1 on the startup ticking being fairly normal on these. Also makes sense that it should be ticking like crazy if it truly has no pressure at idle--and it certainly wouldn't have survived a year of driving with no pressure. Hopefully the pressure test clears things up and it's just bad wiring or a bad gauge rather than the bearings or pump being on their way out.
For reference, the 89 manual suggests at least 9 psi at idle and 67 psi at 3200 rpm with the engine warm. (The 94/95 manual lowered the 3200 rpm spec from 67 to 65, for some reason.)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
