MudFinder95 Posted November 19, 2008 Share Posted November 19, 2008 I haven't drilled anything yet, but I picked up three 6" quartz halogen neon blue lights that are 100watts each. Thats 300watts going to a decent battery and stock alt. Do you think I should get another light so I have 4 across the roof rack (400watts is too much maybe?) or would the 3 look good??? some pics that are too dark and for some reason that one light is shining yellow haha.. vote! Link to comment Share on other sites More sharing options...
silver97ex Posted November 19, 2008 Share Posted November 19, 2008 I think 4 would look better, more symetrical. At least thats what I plan on installing hopefully this weekend Link to comment Share on other sites More sharing options...
bitemedoughboy.com Posted November 19, 2008 Share Posted November 19, 2008 I think 4 would look better, more symetrical. At least thats what I plan on installing hopefully this weekend it looks kinda silly with them sticking up that far above the roof.... would look better if you had a roof rack Link to comment Share on other sites More sharing options...
pktzygt Posted November 19, 2008 Share Posted November 19, 2008 I think 4 looks better. And it does look funny to see them so far back on the roof rack. But if you're like me, I'm proud if I can do something properly and inexpensively. It allows me to do my 280 HP turbo subaru motor swap in my 2060 pound Porsche 914 and modify my pathfinder and still keep the wife happy. It's part of the theme on my pathfinder. I wouldn't spend the money on a light bar either. Link to comment Share on other sites More sharing options...
MudFinder95 Posted November 19, 2008 Author Share Posted November 19, 2008 it looks kinda silly with them sticking up that far above the roof.... would look better if you had a roof rack I do have a roof rack... thats what they are sitting on. the reason they are so high is they are sitting on the top and bottom light mount since i never drilled holes, if I would have they would be a lot lower.. Link to comment Share on other sites More sharing options...
crazyhayseed Posted November 20, 2008 Share Posted November 20, 2008 No, I think he means a safari basket rack, not those silly lengths of plastic that came from the factory. Like This: I'm with the gallery. 4 looks better. Besides, you'd probably get a better effect by 2 pointing straight ahead and 2 turned slightly outward (left and right). Or you could just ditch the odd one and mount two to the bumper like you'd originally planed. Link to comment Share on other sites More sharing options...
nunya Posted November 20, 2008 Share Posted November 20, 2008 I say pick up a 4th, you don't want to be odd do you? But in all seriousness with the 4 setup aimed as crazyhayseed mentioned(how mine are set) does give you a great range of light. I would suggest to Maxima alt. swap though(see the how to threads for benifits,what exactly to get and well, how to). Link to comment Share on other sites More sharing options...
silver97ex Posted November 20, 2008 Share Posted November 20, 2008 I have a safari rack but I plan on mounting my 4 lights on one of the factory roof rack cross bars in front of the safari rack. Aimed as crazyhayseed said. As soon as I get off my butt and mount them, I will be sure to post pictures as well . Link to comment Share on other sites More sharing options...
MudFinder95 Posted November 20, 2008 Author Share Posted November 20, 2008 I'll keep the stock rack.. and I picked up the 4th light today. how big of relay do I need to run all this? the box says 30amp but maybe thats only for one light? Link to comment Share on other sites More sharing options...
91PathSE Posted November 20, 2008 Share Posted November 20, 2008 i have four look at your other post where i but the pic...our truck is the same just mines lifted...I have 4 lights Link to comment Share on other sites More sharing options...
Bobby Posted November 21, 2008 Share Posted November 21, 2008 4 looks the best Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 22, 2008 Share Posted November 22, 2008 A 30 amp relay will be fine for two lights. Let's see...for four lights... 100W x 4 = 400W A=W/V 400W/13.5V = 29.6A I'd use two relays. Link to comment Share on other sites More sharing options...
MudFinder95 Posted November 22, 2008 Author Share Posted November 22, 2008 A 30 amp relay will be fine for two lights. Let's see...for four lights... 100W x 4 = 400W A=W/V 400W/13.5V = 29.6A I'd use two relays. Yeah i'm 3/4's done hooking everything up, I ran two 30amp relays. Link to comment Share on other sites More sharing options...
MudFinder95 Posted November 29, 2008 Author Share Posted November 29, 2008 (edited) "need to know ASAP.., two relays, one switch?" So I'm running four 100w spot lights across my roof rack the box for the lights shows a 30amp relay for two lights. The guy at the store said I should run 2 relays and have one for each pair of lights. Does this mean that I can hook both relays up to one switch????? or do I need two switches for each set of lights which would be kinda annoying. Thanks in advance! Edited November 29, 2008 by RedPath88 Merged Topics Link to comment Share on other sites More sharing options...
RedPath88 Posted November 29, 2008 Share Posted November 29, 2008 I combined these two topics since the second one was just an extension of the first (don't really need two covering the same info) And to answer, Yes you can use just one switch to trip both relays Link to comment Share on other sites More sharing options...
MudFinder95 Posted November 29, 2008 Author Share Posted November 29, 2008 Thanks! Link to comment Share on other sites More sharing options...
