ntwrkguy1 Posted June 18, 2006 Share Posted June 18, 2006 (edited) I've used the search function for the last 20 minutes, and have come up empty. I did learn a few things (location on the 90-95's is a PITA, some people have gone with filter relo kit, etc) but I can't seem to find any post describing the exact location. The owner's manual does a horrible job (shows a drawing of the filter, but doesn't give any details of where it might be!). I know there is a shroud under the Pathy -- does that need to be removed to get to the filter? I can handle a messy filter change, since the filter location on an '01 Ford Taurus guarantees you'll get oil over you and the exhaust pipe! Can anybody provide a precise location for the '97? Or should I just take it to my friend over at Precision Tune? Thanks in advance, David Edited June 18, 2006 by ntwrkguy1 Link to comment Share on other sites More sharing options...
vengeful Posted June 18, 2006 Share Posted June 18, 2006 Just pull off the splash guard, and its right there, right above the axle on the driver's side. Once you get the splash guard off, it's hard to miss. Link to comment Share on other sites More sharing options...
XPLORx4 Posted June 18, 2006 Share Posted June 18, 2006 Yup, oil filter is hiding above the splash guard, nearly directly above the steering rack. And before you pull it off, be sure to drape some rags over the power steering unit, as oil will drip all over it. This is very bad for the steering rack's rubber mount. To minimize the mess, you can place a ziplock sandwich bag over the filter as you unscrew it. The bag will catch and contain the oil as you remove the filter. This is the strategy I use all the time. Link to comment Share on other sites More sharing options...
ntwrkguy1 Posted June 18, 2006 Author Share Posted June 18, 2006 Cool.....thanks for the help!! Link to comment Share on other sites More sharing options...
max_stryker Posted June 18, 2006 Share Posted June 18, 2006 incase you get stuck? or anything Link to comment Share on other sites More sharing options...
max_stryker Posted June 19, 2006 Share Posted June 19, 2006 some better pics, sorry for the dirty, the big bar is the sway bar hope thats a better reference for you Link to comment Share on other sites More sharing options...
vengeful Posted June 19, 2006 Share Posted June 19, 2006 Jeez max....take a pressure washer to that thing!! Link to comment Share on other sites More sharing options...
FUELER Posted June 19, 2006 Share Posted June 19, 2006 ya man your engine looks like its been to sudan and back!!! Link to comment Share on other sites More sharing options...
max_stryker Posted June 19, 2006 Share Posted June 19, 2006 dan that is pressure washed lol Link to comment Share on other sites More sharing options...
ntwrkguy1 Posted June 21, 2006 Author Share Posted June 21, 2006 The pics are great.....I guess I'm going to have to invest in a filter wrench, since I don't think I'll be able to twist that one off by hand! I think the last oil change was done by the dealer, and I'm sure they overtightened the filter! Link to comment Share on other sites More sharing options...
max_stryker Posted June 21, 2006 Share Posted June 21, 2006 well my rule is hand tighten and then back just a smidgen - its quite hard to get filter wrenches up there (depending on which one you have) i would definately see if u can twist it off by hand first Link to comment Share on other sites More sharing options...
