NYpath Posted June 3, 2006 Share Posted June 3, 2006 Can anyone tell me if its only me or what........my 98 pathy sits with the wheels in the shape of a V.....is this a sign for me to get new shocks and struts? or just an alignment? is this normal? did the previous owner have this pathy lifted that i dont know about? can someone give me feed back so i can move on......thanks :help: Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 3, 2006 Share Posted June 3, 2006 Shocks have nothing to do with alignment. I'd have it checked at a shop. Link to comment Share on other sites More sharing options...
max_stryker Posted June 3, 2006 Share Posted June 3, 2006 1996-2004 pathfinders have non adjustable cam bolts. when i lifted mine, i got the V shape also. i had a custom alignment done without buying the 14mm cam bolts from AC by making the holes larger and the shop put in new bolts. i would definately take it to a shop and have it looked at. its a possibility that you may need an alignment. you should post a pic of the truck and maybe we have seen it and knew it was lifted, etc. good luck. let us know how it turns out Link to comment Share on other sites More sharing options...
Trialsin26 Posted June 4, 2006 Share Posted June 4, 2006 Ball Joint maybe? But if that was the case you would have a lot more trouble and probably wouldn't be driving. Link to comment Share on other sites More sharing options...
XPLORx4 Posted June 4, 2006 Share Posted June 4, 2006 FYI, camber is not adjustable without aftermarket parts. Unless you get special camber-bolts, the shop's alignment machine computer will tell the tech that camber and caster are not adjustable, and no attempt to correct camber will be made. Link to comment Share on other sites More sharing options...
NYpath Posted June 4, 2006 Author Share Posted June 4, 2006 im gonna take some pics and you can be the judge of my problem.....thanks for the feedback Link to comment Share on other sites More sharing options...
XPLORx4 Posted June 4, 2006 Share Posted June 4, 2006 im gonna take some pics and you can be the judge of my problem.....thanks for the feedback Does it look like this? Link to comment Share on other sites More sharing options...
dernt Posted June 5, 2006 Share Posted June 5, 2006 Holy camber moly, does that greatly affect your tire wear? Link to comment Share on other sites More sharing options...
max_stryker Posted June 5, 2006 Share Posted June 5, 2006 Holy camber moly, does that greatly affect your tire wear? yes it does lol ill post some of mine if i can find the pic Link to comment Share on other sites More sharing options...
XPLORx4 Posted June 5, 2006 Share Posted June 5, 2006 (edited) Holy camber moly, does that greatly affect your tire wear? It doesn't look like that on level ground. That pic is taken from the top of a steep incline (click link for pic), with a few hundred pounds of camping gear loaded in back, so much less weight is actually on the front tires than during normal driving. Click to view full-size version Edited June 5, 2006 by XPLORx4 Link to comment Share on other sites More sharing options...
NYpath Posted June 5, 2006 Author Share Posted June 5, 2006 it doesnt look that drastic but noticable....its bothering the sheeeet outta me..... Link to comment Share on other sites More sharing options...
asrautox Posted June 6, 2006 Share Posted June 6, 2006 it doesnt look that drastic but noticable....its bothering the sheeeet outta me..... if it's really bothering you, go here: http://www.ingallseng.com/parts/81260.htm Link to comment Share on other sites More sharing options...
max_stryker Posted June 6, 2006 Share Posted June 6, 2006 i think ACs got em for cheaper...not sure about shipping. i have 1 unused set of that too Link to comment Share on other sites More sharing options...
94extreme Posted June 6, 2006 Share Posted June 6, 2006 Does it look like this? daumn, my 94 looks about like that. hmm? Link to comment Share on other sites More sharing options...
Trialsin26 Posted June 6, 2006 Share Posted June 6, 2006 Watch out for this camber adjustment kit "if it's really bothering you, go here: http://www.ingallseng.com/parts/81260.htm". Someone on this list had something similar at the bolts broke causing a grand in damage. Most alignment place can make a custom adjustment and get it pretty close to stock. Link to comment Share on other sites More sharing options...
max_stryker Posted June 6, 2006 Share Posted June 6, 2006 i got my custom alignment done for like $120 Link to comment Share on other sites More sharing options...
