BigBikeMike Posted May 14, 2006 Share Posted May 14, 2006 Where can I get a wiring harness, and in an R50 do you have to run it from the engine back, tap into the tail lights, or is there a simple plug in like on the Xterra? Thanks Link to comment Share on other sites More sharing options...
dernt Posted May 15, 2006 Share Posted May 15, 2006 Hoppy makes a plug in and just about any well stocked auto parts store that sells hitches should have it or be able to get it in a day. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 15, 2006 Share Posted May 15, 2006 There is also a facotry harness available. Taps into both taillamps and isnt too hard to install. Link to comment Share on other sites More sharing options...
t0ast Posted May 15, 2006 Share Posted May 15, 2006 Check ebay for new factory nissan harnesses for pretty cheap. Plugs into the rear plugs at the taillights, and the hard part is having to fish the plugs through existing grommets underneath. Link to comment Share on other sites More sharing options...
RedPath88 Posted May 15, 2006 Share Posted May 15, 2006 PartsAmerica.com lists 12 items ranging from $8 to $73 I don't recall the brand of the one I installed but they are not hard to put in... as t0ast said, it's the routing that is the most difficult part. But again, not to hard Link to comment Share on other sites More sharing options...
BigBikeMike Posted May 15, 2006 Author Share Posted May 15, 2006 Thanks Guys The routing can't be any harder than trying to find a place to go through the firewall to install my amp! I fixed that one with a drill Link to comment Share on other sites More sharing options...
RedPath88 Posted May 15, 2006 Share Posted May 15, 2006 Based on t0ast's description you will have a grommet to go through, that is the same as the WD21's. the thing is that you will be trying to stuff a big connector through a little hole (I kept it as small as possible) and if the R50's are like the WD21's then working space will be an issue... but yeah you can do it Link to comment Share on other sites More sharing options...
Trainman Posted May 15, 2006 Share Posted May 15, 2006 Look here for a bit more info: link Link to comment Share on other sites More sharing options...
t0ast Posted May 15, 2006 Share Posted May 15, 2006 I think its actually much much easier if you pull off the interior panels, which are pretty easy to do. However, I was stupid back then and did it without the interior panels off. I popped off the taillights and pulled the plug out from behind the rubber cover. I think I dropped a weighted wire down into the rear quarterpanel. Then I popped the grommet off from underneath and used the wire to fish the trailer harness plug up. Repeat for the other side. Link to comment Share on other sites More sharing options...
