does it ever end?
sw
vsicks is gonna love this :rolleyes:
stupid front end
dec 05 it copped a new centre link (genuine), a new idler arm (pedders), 4 new tie rod ends (wasp) and my idler arm brace.
in the short space of less than 6 months ive blown 2 tie rod ends and now i find the stupid $145 new idler arm is stuffed as wel..... :angry:
i ripped the arm apart to see what was wrong. NOT very impressed with what i saw. basically 2 metal bits, 2 plastic bushes, a washer and a nut. i have found that the plastic bushes are hammered and are sloppy as.
so i grabbed my old original idler arm, the one which the new arm replaced, pulled it apart to find basically the same thing other than the nissan arm has a seal on each end. i guess that why its last MUCH, MUCH longer. so i ve ordered 2 new bushes from nissan and im gonna hope for the best.
i also found that the bushes in the new arm ae ALOT sloppier than the original arm bush. what gives - a six month old part more stuffed than an 18 year old part. :angry::angry::angry::angry:
basically ive wasted $145. :angry::angry::angry::angry::angry::angry::angry:
attached is the new arm
had thought about brass bushings.
i might take down all the details of my new bushes, which ive already ordered, so ive got all the dimensions if i wanna knock up so brass ones instead.
as for ac, im not getting anything from the u.s.
No not myself, but in the US we have access to companies that produce just about any bearing you could need. Both sealed (several ways) and unsealed. A quality ball bearing would allow for smoother operation and likely give a much longer wear life.
Perhaps you have access to a company that can provide a suitable replacement?
Cost may be an issue though... but compared to the 6 months that your repllacement lasted.. maybe some additional cost is worth it :shrug:
good idea
gonna try the genuine nissan bushes first, then i would go some brass ones if they crapped out quick smart.
they also have brass bushing replacement at AC
WOW, I had NO idea that they were plasic !! I wonder what kind... Maybe a tougher plastic can be used, but I whould Highly recommend Oil-lite bronze... Tougher than brass and oil impregnated for self lubrication...
Brass bushings would be an improvement but will have to be custom-machined.
I suppose thats true, but hardly what I would call machining... Someone send me dimensions of the pieces the bushing rides on and the basic bushing geometry or an unabused bushing and a discription of the fit. Those would be simple to make on a hand lathe. I'll make a set for a guinne pig...
Yep - plastic bushes.
pretty average i reckon.
precise as stated above i will measure up the new bushing from nissan that i get.
i have a friend that is a machinist so if i need some he will knock em up for me.
Edited by sw
