iLLlegal Posted April 9, 2006 Share Posted April 9, 2006 ok so I was just inspecting my engine bay today and I noticed this and a closer shot now i dunno what that thing is. or what it does. it lookes like the previous owner put glue on it to hold it in there. should I just leave it? Link to comment Share on other sites More sharing options...
Slick Posted April 9, 2006 Share Posted April 9, 2006 that my dear boy is your charcoal cannister (land of exhaust recycling).. and you will/should have the most holacious vaccum leak if it is not repaired.... is your pathy running like crap or your rpm's going mental yet? that is what hose was leaking on mine and it solved my rpm problem soon as i put a new clip on it mine broke in the same place with PO as it looks to be super glued on there Link to comment Share on other sites More sharing options...
iLLlegal Posted April 9, 2006 Author Share Posted April 9, 2006 oooo charcoal cannister. i might have broken that when i hit a tree...like a yr ago hmm vaccum leak. that sounds bad. i mean i havent noticed any rpm stuff. it doest feel like its running like crap. how would i fix it? like it doest look like a cap. that thing looks like one big peice that i cant take apart. re glue it? Link to comment Share on other sites More sharing options...
Slick Posted April 9, 2006 Share Posted April 9, 2006 you can try gluing it.. if all else fails buy a new cannister (about $90) or go get one off a JY pathy Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 9, 2006 Share Posted April 9, 2006 Glue's not gonna hold that together. Stuff a golf tee into the rubber hose and call it good unless you need to pass emissions... Link to comment Share on other sites More sharing options...
mws Posted April 11, 2006 Share Posted April 11, 2006 I've had remarkably good luck gluing plastic together with, of all things, JB Weld! Clean the parts thoroughly with electrical cleaner, and give it a try. Glob as much JB as you can, and if possible, shove some kind of reinforcetment into the epoxy as well. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted April 12, 2006 Share Posted April 12, 2006 If you're really trying to fix it and save a buck with glue, I wonder if you could go over the top of your repair with a couple small strips of fiberglas cloth and resin. You can pick up a small do-it-yourself patch kit pretty cheap at most any auto parts store, and that could provide the reinforcement to hold the glue/epoxy/JB Weld/bubble gum repair you choose to try. Link to comment Share on other sites More sharing options...
rxf610 Posted April 12, 2006 Share Posted April 12, 2006 Don't put too much glue and clog the hole though. That would render it pointless. I say glue with epoxy or jb weld, and hope it stays. If not junkyard it for a new cannister. Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 12, 2006 Share Posted April 12, 2006 I've had remarkably good luck gluing plastic together with, of all things, JB Weld! Clean the parts thoroughly with electrical cleaner, and give it a try. Glob as much JB as you can, and if possible, shove some kind of reinforcetment into the epoxy as well. spoken like a true engineer... so question about this canister if i dont have to pass emissions and could remove it...could i possibly increase gas milage without hendering the trucks operational ability Link to comment Share on other sites More sharing options...
mws Posted April 13, 2006 Share Posted April 13, 2006 Thanks! The charcoal canister won't noticeably affect fuel economy one way or the other (functioning or fully bypassed). Having it functional MIGHT increase mpg by .0001% or so, but that's about it. All it does is absorb the evaporating gas vapors from the fuel tank when the truck sits. Without it, your truck will tend to smell like a gas station on hot days (as anybody who has owned an older car can attest to!). That's why I keep mine intact and functioning - I hate the stink. Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 13, 2006 Share Posted April 13, 2006 ahh good stuff wasnt really sure of what it did guess its a good thing its still intact...although i like getting in some american muscle that smells like fuel just something about the cars Link to comment Share on other sites More sharing options...
iLLlegal Posted April 13, 2006 Author Share Posted April 13, 2006 thanks for all the help guys. ill try the glue this weekend Link to comment Share on other sites More sharing options...
