New intake/cone filter
GrimGreg
So, I finally got around to doing this little mod today. I made a custom tube between the MAF and TB and put a cone adapter on the MAF. B)
What do you think?
I used Spectre Performance parts to build the custom tube.
It's much more agressive when you hit the gas, less hesitation on throttle responce. :aok:
I do plan to make a sheild for it to help keep mud and hot air away (my fender liner is toast). As for water, my 93 is semi-retired from wheeling, it is getting a run next month, but I will avoid the deep stuff. One nice thing, if I really wanted to I could go back to the stock air box since I didn't destroy anything, only removed and remounted the MAF piece. And, I could do that and keep the new tube on there (though I might need to add a 22degree angled tube onto that to line it up right. One main reason I did remove the box was 2 of the clips that hold the top on had broke, so I was using a bungee cord to keep it on :blink: .
