Big issue help!
Pathfinder-jay
Its a manual transmission.... 91 pathy 4x4 4 dr xe. Last thing i did was replace my dash as in the speedometer and rpm manifold there.... other then that nothing. Got my oil changed but the oil level is fine... It doesnt stop but when i rev higher then 2-2.5 my car hops
hops as in bucks like it's starving for fuel? does it actually DIE? or when the rpms go down it is ok again? have you changed your fuel filter lately? no.. a fuel pump going out won't show any visible signs... unless you have a fuel line gone.. but i am sure you'd notice the gas mileage drop and or smell the leaky gas
It's 2800 RPM's, and either your TPS or your MAF is damaged or unplugged. The ECU runs the engine in "safe mode" if either of those sensors is non-responsive to prevent leaning out the engine and causing damage via detonation.
Check the throttle position sensor and the mass airflow sensor.
fuel filter is relatively easy.i use clamps to stop the flow of gas..remove gas lines... put them on new filter and away you go.
MAF sensor is here: (circled in white) it connects to the side of your air filter box snd is held on by 2 screws.. remove and GENTLY clean the (they look like light bulb wires) wires with alcohol. if you break them.. it's expensive.
And the fuel pump sensors or all sensors i should check are located where exactly? if u dont mind... sorry
any sensors will be visible if unplugged. check around the driver side (LH) of your motor for any sensors that may have come unplugged.. check closely as there are hidden sensors all over. check your entire engine for anything amiss.
also.. if you didn't have the battery disconnected when you did whatever (i forget) you did.. disconnect your batter for 10 minutes to let the ecu reset itself.... AFTER you have checked to make sure everything is in order... that outta keep you outta trouble for a few minutes.. then we'll go from there eh ;)
I got the book, sorry guys my first car.... just nervous to fool around under the hood. OK now strange thing is this.... Next morning I start my car...drive to the garage no issues it runs like a dream....later tonight it starts acting up again. I go to a movie.... it doesnt hop anymore after the movie but it idles at 2 rpm... im used to idling at like 800-1000 rpm and 1500 when its realy cold out. Any ideas guys... I wanted to bring it to my mechanic but it wasnt having issues, so he told me to keep driving and see if it starts up again... and it did.
Thanks for the help guys
Jason
