UCA's
headpeace
the UCAs bolt onto the ball joints.
As for ease of install, either replacing UCAs or Ball joints can be done seperately, or together. I think Id do them at the same time, but you wouldn't be saving yourself any time over doing them seperately.
I did mine over the summer and bolted the ball joints to the UCA's first, then installed the whole thing. Easy as pie. Plus its probably easier to line up one hole (the bottom of the ball joint) than 4 holes (the ball joint to UCA) when you're mounting it up.
