hastifc Posted November 20, 2005 Share Posted November 20, 2005 my vg30i is having issues, and i am soliciting advice for options on replacement. i live in the seattle region. complete rebuild, jdm engine, or junkyard? if rebuild, who? if jdm, who? if junkyard, who? prices? Link to comment Share on other sites More sharing options...
lgranch Posted November 21, 2005 Share Posted November 21, 2005 You can replace your VG30I with lots of different choices.... wrong. Unless you want to change out the computer and the wiring harness you are stuck with a VG30I. You could also change out the intake for the carburator. Now a potential problem with JDM is that you will have to change out compoents also to match ou pathy. A good rebuild kit will run about $650 and takes alot of time. Junk yard motors have the problem in that you do not know what you are getting. You did not say what the issues were nor did you say auto or 5 speed. These could influence you decision. Link to comment Share on other sites More sharing options...
hastifc Posted November 21, 2005 Author Share Posted November 21, 2005 1 cyl low on compression, sitting at 100 lbs., and a botched xh stud removal ending in broken drill bit in head with a pierced water jacket. and a leaking rear main, and serious lack of power. the other cyls were sitting around 130-140 lbs. auto, so i need all the power i can get.... Link to comment Share on other sites More sharing options...
Precise1 Posted November 22, 2005 Share Posted November 22, 2005 Well, sounds like it needs work for sure although a rebuild doesn't adress the water jacket issue. Is that something that can be welded ? Would you do the rebuild yourself ? B Link to comment Share on other sites More sharing options...
hastifc Posted November 22, 2005 Author Share Posted November 22, 2005 in another time i would rebuild myself, but now i lack time and patience. i located a jdm motor for 729.00. 12 mo warranty from a local place. sound reasonable?? Link to comment Share on other sites More sharing options...
Harbinger Posted November 22, 2005 Share Posted November 22, 2005 Sounds pretty good to me -- Never had to replace an engine myself, but thats only slightly more than an rebuild kit (as listed above) and comes with a warranty. Of course I'd say spend the money and swap with a 350, but thats just an very expensive option :-) Link to comment Share on other sites More sharing options...
Precise1 Posted November 22, 2005 Share Posted November 22, 2005 $729 for a motor with 12 month warranty is not bad at all. First thing I would do is compression check it as soon as it is installed, and if anything is weak, blow it up... B Link to comment Share on other sites More sharing options...
Casey.T Posted November 22, 2005 Share Posted November 22, 2005 $729 for a motor with 12 month warranty is not bad at all. Is that with a Core??? The one I have here locally is $850, no core fee. Link to comment Share on other sites More sharing options...
hastifc Posted November 22, 2005 Author Share Posted November 22, 2005 will let you know, casey Link to comment Share on other sites More sharing options...
Casey.T Posted November 22, 2005 Share Posted November 22, 2005 It would be worth the 2 tanks of gas for me to drive to Seattle Area to pick on up for myself if no core. The one here in Spokane only has a 90 warrenty. Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 foreign motors in lynnwood, wa. 649.00 +tax, like 706.00 total 1-800-333-9889, no core. 12 mo, unlimited miles warranty. ask for nick, tell him fred hastings just ordered one. Link to comment Share on other sites More sharing options...
Casey.T Posted November 23, 2005 Share Posted November 23, 2005 $709 +tax delivered to Spokane with the 12mo unlimited Milage warrenty :contract: Good Find :cool2: If i pick it up it would only save me $50, Difference there is I get to look at it before $$$$$. Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 you order? Link to comment Share on other sites More sharing options...
Casey.T Posted November 23, 2005 Share Posted November 23, 2005 I am on the verge of ordering it. I have this thing about seeing it first. Trying to make arrangements for a friend of my from over there to go look at it before I $$$$$. And if they are headed this way I get to save $50. I will know more on friday... they open on Saturday??? 3.5 hours to get there myself hmmmmmmmmmmmmmm..... Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 got mine today. very clean, painted, no oil anywhere Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 want pics? Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 heres 1 Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 heres 2 Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 heres 3 Link to comment Share on other sites More sharing options...
hastifc Posted November 23, 2005 Author Share Posted November 23, 2005 and the money pit. 2 months and 2500.00 into it. email me if you want my ph #. Link to comment Share on other sites More sharing options...
Slick Posted November 24, 2005 Share Posted November 24, 2005 That's a ncie money pit Link to comment Share on other sites More sharing options...
Casey.T Posted November 24, 2005 Share Posted November 24, 2005 email sent -bounce- Did you go look at it or did they just ship it to you? Link to comment Share on other sites More sharing options...
Precise1 Posted November 24, 2005 Share Posted November 24, 2005 Cool !! Keep us informed about it !! B Link to comment Share on other sites More sharing options...
hastifc Posted November 24, 2005 Author Share Posted November 24, 2005 will do Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 26, 2005 Share Posted November 26, 2005 Hey, I wonder if there's any benefit to running a JDM intake like the one on there. That's nothing like the regular VG30E US-issue intake. o.o If you want to get rid of that intake and FI setup, let me know. I wouldn't mind having that to play with. Link to comment Share on other sites More sharing options...
