Fog Lights?
BigBikeMike
  • 4 months later...
Guest riels
I got a set of oem fogs .... any idea where I can find some installation directions ?? I'm sorta lost ..... furr shurrr
What year Pathfinder are you looking for help on? The installation would be different based on the year of your truck.
let's see... he's in the 96-04 forum and his profile says he's driving a 98. sheesh Dan!
1996-1999 had small, rectangular fogs in the middle of the bumper.
1999.5-2004 had integrated fogs in the lower corners of the bumper.
Completely different, and a big deal.
Take that, WD driver! ;)
:P
  • 3 weeks later...
The 00's use the newer style of fogs
That is what nissan used from the factory but you can use older style bumper lights under the grill but above where a license plate would go you will see factory mounting holes or you can fit similar rectangle lights in for a very factory look. I'm going to add lights there but im not sure what pattern i want, probably like a tractor flood light that will light up alot real close.
Edited by 4x4le
http://npora.ipbhost.com//index.php?act=At...=post&id=115823
How are these adjusted? Mine shine about 2 feet in front of my bumper, and I'd like them to project out a little further.
They really arnt made adjustible but you could use a 100w bulb and add washers to the bottom bolt holding it in like me! It makes them shine out a little farther, when my brights are on, there is no gap in the light on the road that i can see from my fog lights to my high beams!
