maximusnt Posted November 10, 2005 Share Posted November 10, 2005 Hey folks, so I need to seafoam my engine tonight. I've already put a 1/3 in the gas tank... Which hose should I use to run Seafoam into the engine directly. I've heard the brake booster line mentioned, and I think there's also a line going to the airbox that might be easier to access. Thanks! Link to comment Share on other sites More sharing options...
XPLORx4 Posted November 10, 2005 Share Posted November 10, 2005 What year is your truck? On my 97 this is the hose I used (EVAP line): Link to comment Share on other sites More sharing options...
vengeful Posted November 10, 2005 Share Posted November 10, 2005 (edited) Seafam recommends using the Brake Booster Line, though the EVAP line works just as well....basically any of the vac lines that get the stuff straight into the manifold (not through the airbox), will be fine. Here's a diagram from the FSM that should hopefully help out: Edited November 10, 2005 by vengeful Link to comment Share on other sites More sharing options...
maximusnt Posted November 10, 2005 Author Share Posted November 10, 2005 (edited) Forgot to mention, this is for a 2002. Thanks Vengeful, I'm looking for specific locations on the engine, so I can tell when I'm looking at it in the dark... LOL Edited November 10, 2005 by maximusnt Link to comment Share on other sites More sharing options...
vengeful Posted November 10, 2005 Share Posted November 10, 2005 It'll be between your brake master cylinder and your intake manifold, running through a bracket thinger on the firewall. Hmm...it's been about 50,000 miles since I SeaFoamed my truck...I should probably do that sometime soon. Link to comment Share on other sites More sharing options...
maximusnt Posted November 10, 2005 Author Share Posted November 10, 2005 So, where exactly is the brake master cylinder? Link to comment Share on other sites More sharing options...
vengeful Posted November 11, 2005 Share Posted November 11, 2005 Its the big black thing with the brake fluid reservoir on top of it mounted to the firewall. Link to comment Share on other sites More sharing options...
dernt Posted November 12, 2005 Share Posted November 12, 2005 What is seafoam? Link to comment Share on other sites More sharing options...
kmgar99 Posted November 12, 2005 Share Posted November 12, 2005 Just read about Seafoam......sounds like a decent product.....Does It Work? My intake manifold interior is all black and needs to be cleaned..... Link to comment Share on other sites More sharing options...
vengeful Posted November 12, 2005 Share Posted November 12, 2005 It works WONDERS....will smoke out your neighborhood though.... Link to comment Share on other sites More sharing options...
IndianRider Posted November 17, 2005 Share Posted November 17, 2005 just did the seafoam at lunch hour .. poured 1/3 in gas tank and have around 5 gallons left in gas tank so that must be PRETTY concentrated in there now .. started the pathy, then disconnected the brake booster line and let the motor suck in around 1/3 of seafoam.. the pathy would die with the vac. hose off, so had to manually keep the revs up with the other hand .. it didnt smoke a lot at all .. just saw more white smoke than usual but def. not what ppl. have been saying or no black smoke at all .. have 1/3 left.. any harmful effects pouring it in the motor ? does the engine oil need to be changed immediatly, like say 25-50 miles of driving ? dont really notice a "smoother" idle or revving effect.. maybe the product does clean crap out and itss hard to notice .. the 96 pathy has 113k miles and was running strong and silky anyways .. Link to comment Share on other sites More sharing options...
IndianRider Posted November 18, 2005 Share Posted November 18, 2005 just an update... did the sea foam cleaning at lunch at noon .. drove back to work ..2 miles no problem .. driving back home from work at 5 pm , 5 miles later, CHECK ENGINE light came on .. took it to autozone .. forgot to get an exact printout of codes , but were in the 300 series.. O2 sensor malfunction on bank 1 , sensor # 2 (left ?) and multiple cylinders misfiring codes .. asked them to reset it ..went out for a 30 mile freeway ride, kept stomping on the throttle at times to get the crap out .. drove with OD off at 65 mph, like near 4,000 rpm to open it up and let it burn up the carbon and seafoam .. no diff. in running, still smooth as before seafoam .. check engine light didnt come on this time .. still runs smooth ... no problem yet and i think its nothing .. just carbon burning / emissions prob. threw the sensors off.. Link to comment Share on other sites More sharing options...
vengeful Posted November 18, 2005 Share Posted November 18, 2005 Did you hold the engine RPMs at 2,000-2,500 until the smoke stopped coming out of the exhaust after doing the seafoam? Link to comment Share on other sites More sharing options...
IndianRider Posted November 18, 2005 Share Posted November 18, 2005 no i didnt rev. the motor until the smoke stopped coming ..like i said, there wasnt much smoke coming out even after i put more than 1/3 of sea foam .. so i revved it for maybe 30 seconds then drive 2 miles to work .. then after 4 hrs, i was driving back home and thats when the check engine light came on ..so maybe i didnt burn all the seafoam out and it was super concentrated there causing sensors to trigger.. im not worried about it coz i got the check engine light twice before in HOT conditions driving in 3rd in the smoky mountain range on 87 octane .. so in HOT summers on long trips i put in the next highest octane gas (88 or 89) and haul ass and never got the light to come on again.. Link to comment Share on other sites More sharing options...
DJ Dank Posted December 20, 2006 Share Posted December 20, 2006 Just seafoamed the Pathy this afternoon for the first time. There was a $hitload of smoke that came out. It was funny driving around the neighborhood leaving a trail of smoke. First thing I noticed was how smooth the car idled. But after reading a few posts on here about it, I didn't pour it into either of the recommended vacuum lines. I used one of the two vacuum lines that was attached to the intake tubing elbow using a funnel to pour it in. But seemed like it still did its job. Link to comment Share on other sites More sharing options...
