Pathylogical Posted September 17, 2005 Share Posted September 17, 2005 I know backspacing is yalked about a lot and a search would bring up pages of results that is the problem, I have tried. Which way does the tire move with greater backspacing? If you went from 4 inches to 4.75 inches would the tire stick out of th wheel well more? If I am going for 15x8's with a 31 inch tire is 4.5 backspacing right with a 3 inch Calmini susp lift ? Thanks guys, Pathylogical Link to comment Share on other sites More sharing options...
Slick Posted September 17, 2005 Share Posted September 17, 2005 I have the JGC coil lift, with 31's on Chevy 6 lug rims with 3.5" of BS..I think my other set have 4" of BS. 4" is really the highest you want to go, as yes, the bigger the BS number, the further they stick out. There are laws about how far your tires/rims can stick out..not that I have ever heard of anyone getting a ticket for it.... good luck! Link to comment Share on other sites More sharing options...
Duffman Posted September 18, 2005 Share Posted September 18, 2005 4.5 is too big, I have 3.5 and its way out there already. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 18, 2005 Share Posted September 18, 2005 Just Google it. One search and I find: Backspacing: The distance from the back edge of a wheel rim to the back of the center section. A higher BS number indicates a wheel with the majority of the rim space on the wheelwell side. A "0" offset rim is a neutral wheel with equal amounts of rim between fender and curb, and a wheel with an low-number offset of -4 would cause the tire to stick way out of the wheelwell. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted September 18, 2005 Share Posted September 18, 2005 We call it offset in the land down under. Link to comment Share on other sites More sharing options...
SteveWA Posted September 18, 2005 Share Posted September 18, 2005 Yes and in the land down under if ya tire sticks out past your fender then say hello to Mr. Copper!!! Link to comment Share on other sites More sharing options...
RedPath88 Posted September 18, 2005 Share Posted September 18, 2005 We call it offset in the land down under. Which would probably be far less confusing for most people Link to comment Share on other sites More sharing options...
RedPath88 Posted September 18, 2005 Share Posted September 18, 2005 Yes and in the land down under if ya tire sticks out past your fender then say hello to Mr. Copper!!! We are allowed 2in here (last I checked anyway), but really it depends on the officer. Some simply don’t care and some seem to hate 4x4’s. Link to comment Share on other sites More sharing options...
Precise1 Posted September 18, 2005 Share Posted September 18, 2005 As 88 implied, offset and backspacing are two different measurements. Knowing one and the width of the rim, you can calculate the other. Sometimes it is necessary to know both for proper fitment and clearance... B Link to comment Share on other sites More sharing options...
Pathylogical Posted September 18, 2005 Author Share Posted September 18, 2005 I swear in other posts I saw recomendations to go with anywhere from 4.25 to 4.75. Now all you guys say over 4 is too much. and into the 3's would be better. Anyone else want to weigh in on what BS they are running. It will be a 85 with the 3 inch Calmini susp. lift and 31 inch tires. Thanks again Dan Link to comment Share on other sites More sharing options...
Mookie Posted September 19, 2005 Share Posted September 19, 2005 I swear in other posts I saw recomendations to go with anywhere from 4.25 to 4.75. Now all you guys say over 4 is too much. and into the 3's would be better. Anyone else want to weigh in on what BS they are running. It will be a 85 with the 3 inch Calmini susp. lift and 31 inch tires. Thanks again Dan Perhaps the confusion is with the terminology being used. (backspacing vs. offset) With Backspacing, the lower the number, the further out your tires will stick out. Stock Pathys (at least the older ones) are 4.75"-5.0" of backspacing. I went to 3.75" backspacing with 33's and they stuck out about 2" past the fenders. I would go to around 4.0-4.5. I have 3.25" and they really stick out. ...then again I could have it backwards!... Link to comment Share on other sites More sharing options...
Pathylogical Posted September 19, 2005 Author Share Posted September 19, 2005 God I hope not mookie that ansers my question! unless you do then I am all bass ackwards. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 19, 2005 Share Posted September 19, 2005 I swear in other posts I saw recomendations to go with anywhere from 4.25 to 4.75. Now all you guys say over 4 is too much. and into the 3's would be better. Anyone else want to weigh in on what BS they are running. It will be a 85 with the 3 inch Calmini susp. lift and 31 inch tires. That's unlifted with 31's. Lifted with 32's or 33's, it's desireable to have a little less BS to keep the tires in the right place and avoid fender rubbing or damage. I have 33x13.50x15" Super Swamper LTB's on 15x8.5" alloy generic wheels with neutral backspacing. That gives me about 4 1/4" of BS with an 8.5" wide rim. Link to comment Share on other sites More sharing options...
