95 to 87 swap
Guest My1stImport
Guest My1stImport
Hey guys, I'm about to try something and need some advise. I've got this '95 SE 4 door that is in real bad shape. The entire driveline is good, I've never had a mechanical problem out of this truck. The rest of the truck, body, interior and so on, is beyond repair.
I'm about to buy an '87 2 door thats just the opposite. I can get this truck for reel cheap and I was thinking about swapping out the engine and other good parts. What, if any, problems am I going to run into? I plan on swapping the engine, auto trany and some suspension componets that seem to be missing.
I'm not sure about the fittment issues between an 87 and a 95, but instead of swapping evrything over, take a look at pulling te 95 body off and putting the 87 body on the 95 frame. No motor or trans or other stuff with a thousand bolts and sensors to mess with that way. Plus you could take a really good look at the condition of the frame and other items that would be near impossible to fix with the body on. Just a thought.
Good luck.
let me know if you want to recover some cash from your 95 leftover parts. I need a part from a power antenna that is apparently not available seperately from the dealer.
  • 3 weeks later...
  • 1 month later...
i used:
4 12 ft 4x4's sunk at 2 ft
2 4x4x8' for the front and rear cross supports
couple scrap 2x4's to make the verticla supports
scrap picket fencing for the bottom braces
2 2 ton boat winches (the reel type with the 3 in straps and hook not shown in pix)
these pix were using a come-a-long and some rachet straps to hold it in place...but this is now how it was done to actually remove the body due to the safety issues....it was just 1 of those deals where i finally got it all up and wanted to see if it was gonna work...but the next day i went and got the boat winches and drilled a 2 holes in the center of the front and rear cross 4x4's so the u bolt would go thru and the winch could mount so the handle could be spun to allow it to be cranked up...did the front and rear a little at a time...very sturdy wouldnt even budge..and didnt concrete in the posts due to the fact that my grandfather wouldnt let me....
:clap:
I like it, good thinking !! :D
Same here, I'd LOVE the AC condensor, mounting hardware and drivers side line all the way to the pump from the 95 if it is available !!
