peejay Posted December 13, 2024 Share Posted December 13, 2024 Is there an aftermarket source for thi or does it hafta be Genuine Nissan? I ordered a Gates one, but it's too loose/looks like a different design. Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 14, 2024 Share Posted December 14, 2024 What are you looking for? The WD21 power steering belt does not have an idler pulley. That looks like the aircon belt tensioner for a VQ R50, or at least there's an SKP part listed for that on Rockauto that looks nearly identical. Link to comment Share on other sites More sharing options...
peejay Posted December 14, 2024 Author Share Posted December 14, 2024 Whoops, busted, forgot which forum I was in! It's a WD21 with a VG33. (I went ahead and ordered it from Nissan parts deal, couldn't find it (reliably) elsewhere.) Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 15, 2024 Share Posted December 15, 2024 Ah, you kept the VG33 accessories. That explains it. If it's just the bearing that's clapped, you may be able to rebuild the old one. Link to comment Share on other sites More sharing options...
adamzan Posted December 15, 2024 Share Posted December 15, 2024 You absolutely can, @Slartibartfast. I've done it for all 3 pulleys on my Xterra. Link to comment Share on other sites More sharing options...
peejay Posted December 19, 2024 Author Share Posted December 19, 2024 Oh? Pics? Does rebuilding require a press? Here's a pic of the backs of pulleys, OEM one on the left, incorrect aftermarket one on zee right: Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 19, 2024 Share Posted December 19, 2024 (edited) A press would make it easier, but you could probably make due with a bench vise. Use a socket to drive the bearing, and make sure you're putting force into the race you're trying to move, not through the bearing balls. (If you're pressing the OD into the pulley, press on the outer race, not the inner.) I'll bet the center spacer and dust shield whatsit would pop out of the old bearing and into the new one. I doubt you'd even need a press for that, should just slip out if it's like other idlers I've messed with. Edited December 19, 2024 by Slartibartfast 2 Link to comment Share on other sites More sharing options...
gamellott Posted December 19, 2024 Share Posted December 19, 2024 7 hours ago, Slartibartfast said: A press would make it easier, but you could probably make due with a bench vise. Use a socket to drive the bearing, and make sure you're putting force into the race you're trying to move, not through the bearing balls. (If you're pressing the OD into the pulley, press on the outer race, not the inner.) I'll bet the center spacer and dust shield whatsit would pop out of the old bearing and into the new one. I doubt you'd even need a press for that, should just slip out if it's like other idlers I've messed with. Agreed. That step down in size is likely a bushing/spacer that is probably rusted in place and would probably come out if given the proper force. 1 Link to comment Share on other sites More sharing options...
peejay Posted December 23, 2024 Author Share Posted December 23, 2024 (edited) Thanks, all! Happy Holidays! (Edit) As usual, you all were right! Maybe if I'd've serviced this thing years ago, the cover/spacer wouldn't've been seized on there, and would've just fallen off, like the new one did! (This pic might show the spacer/bushing thingy better): Edited December 23, 2024 by peejay 2 Link to comment Share on other sites More sharing options...
