Rear Engine Camshaft Gaskets
gamellott
Long Story Short, The gaskets on the back side of the heads where the camshafts are inserted into the heads are leaking. I cheeped out and I reused the old ones when I replaced the head gaskets and now that I have identified where the current leak is from, I don't have faith that they're going to hold on in the long term and I want to replace them. I imagine that could be catastrophic to the heads if those gaskets outright fail.
I have the new gaskets, but I was wondering if anyone has experience in replacing those with the transmission out with the intake removed. I do have a new head gasket set, but taking the heads off is a pretty serious undertaking. I've done it 😑 I'm game to pulling the transmission since those seals are almost the last remaining leakers that I have on the vehicle, and I have no idea what condition the clutch is in. I just know that it still works.
Thoughts, Recommendations?
I'll bet you could get to those bolts with just the upper intake removed. I recently replaced my knock sensor (which I had previously relo'd to the back of the driver's side head, inboard of the cam cover plate) without pulling the intake. If I could get to that, I'll bet you can get to these. With the intake out of the way, you might even be able to see what you're doing.
You could get to them with the trans off, that's a lot of work but if you have other leaks, might be the best 2 birds with 1 stone approach.
Here's what mine looked like when I pulled the transmission on my old 1994 to replace with an Xterra trans. You can see there is some decent room there:
