04 Pathfinder Rear differential on 97 Pathfinder
AR97Pathfinder
Hello everyone, the differential on my 97 Pathfinder with 220k miles has been humming for a few years now on the highway. Is it possible to swap over the 3rd member from an 04 Pathfinder? I am wondering if I can simply swap the 3rd member from the 04 Pathfinder into the differential housing on my 97 Pathfinder?
Thank you
1 hour ago, AR97Pathfinder said:
Okay, thank you. If I were to get a HG46 differential from an Xterra or Frontier, would that swap right in without any issues?
Yes, provided it's late 00-04 Frontier or 00-04 Xterra.  99 and early 00 Frontiers had 31-spline diffs and slightly different 4.625 ratios.  96-00 Pathfinders and the years I mentioned are 33-spline and had 4.636 available.  01-04 Pathfinders were only 4.363 ratios.
All of those year 3rd members will bolt in, it's just the different ratios and splines to be aware of.  And of course if you want (or want to keep) an LSD unit.
