Frenchy Posted November 8 Share Posted November 8 So recently I started to notice my 93 Pathfinder to have a vibration on Deceleration (slowdown) between 50-60 MPH. I did a little bit of looking underneath and couldn't see any obvious issues. I decided to take a peak at the rear drive shaft and notice an odd bit of play with the slip yoke to the output shaft in the transfer case. The way to describe the play was like the back and forth movement used to check for a bad wheel bearing. Has anyone else run into this before? I won't argue that with almost 300,000 miles it that the slip yoke could have some play as it should be a somewhat softer metal(not by much) that the output shaft of the transfer case. Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 11 Share Posted November 11 What sort of play? Rotating, radial? Either way, I wouldn't expect it to only act up on decel. How's the oil level/condition in the rear end? Link to comment Share on other sites More sharing options...
adamzan Posted November 16 Share Posted November 16 I would also look at your u-joints. Link to comment Share on other sites More sharing options...
Frenchy Posted November 18 Author Share Posted November 18 U joints are fine as I did check that. I was able to find a bushing for the tailshaft housing of the transfer case(just a question of when I can get it replaced). As for the vibration I got it narrowed down to the engine area and might have just found the problem without knowing it. Was about to start the New Mexico Back Country Discovery Route tomorrow and on my way to Alamosa tonight the Fan Clutch decided to fail in the locked up position with 20-25 miles to go. Thankfully a local auto parts store has one in stock that I'm getting in the morning. Yes it is aftermarket but it is better than nothing. Link to comment Share on other sites More sharing options...
adamzan Posted Thursday at 03:34 AM Share Posted Thursday at 03:34 AM Can you even get OEM fan clutches for these anymore? My local dealer didn't want to put in the effort to locate stock so I just bought one at NAPA... Hasn't blown up or overheated so far. Link to comment Share on other sites More sharing options...
Frenchy Posted Thursday at 04:57 AM Author Share Posted Thursday at 04:57 AM Yes and no. The VG33E fan clutch is a direct bolt on and operates in the same temp range. The one from O'Reilly's is working well for now, so I may just leave it be Link to comment Share on other sites More sharing options...
