19eddies Posted December 29, 2022 Share Posted December 29, 2022 I got a new key fob for my 97 r50 and followed the instructions to the letter for programming. The hazards flashed as they should but the remote still doesn't work. Any suggestions as to what I can do to make it work? I checked the fuses and all is good and I replaced some faulty door switches with junkyard replacements and no door open light on the dash so I'm stumped as to what the problem is. Any suggestions would be appreciated Link to comment Share on other sites More sharing options...
Luis_Rada21 Posted January 17, 2023 Share Posted January 17, 2023 (edited) Hola ¿Donde compraste el control remoto? Necesito uno pero vivo en Colombia. Edited January 17, 2023 by Luis_Rada21 Link to comment Share on other sites More sharing options...
CALPATHY Posted January 18, 2023 Share Posted January 18, 2023 Try to program it again, sometimes it doesn't work on the first try or two (not that I would know). Link to comment Share on other sites More sharing options...
Strato_54 Posted January 18, 2023 Share Posted January 18, 2023 (edited) When I had to redo both of mine, only the 1st one would actually work even though the flashers went. After the flashers go, unlock then lock the door with the switch. This for some reason worked. I found that on page 5 after google surfing. Not sure why all the other instrustions didnt mention this. Edited January 18, 2023 by Strato_54 Link to comment Share on other sites More sharing options...
