Programming key fob 97 r50
19eddies
I got a new key fob for my 97 r50 and followed the instructions to the letter for programming. The hazards flashed as they should but the remote still doesn't work. Any suggestions as to what I can do to make it work? I checked the fuses and all is good and I replaced some faulty door switches with junkyard replacements and no door open light on the dash so I'm stumped as to what the problem is. Any suggestions would be appreciated
  • 3 weeks later...
When I had to redo both of mine, only the 1st one would actually work even though the flashers went. After the flashers go, unlock then lock the door with the switch. This for some reason worked. I found that on page 5 after google surfing. Not sure why all the other instrustions didnt mention this.
Edited by Strato_54
