XTERRA transmission in 96 Pathy 2WD
atlakeem
ok so i found an 04 xterra transmission online 158k miles for a good price. Its an actually shop that sells it. They say the wiring may differ from my vehicle, which is a 96 Pathy. Anyone know for certain that the wiring will match with no problem? I've search but can't find someone who actually did the swap. (non-supercharged tranny btw)
Should be plug and play.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Edited by Cuong Nguyen
You will need:
Xterra trans (obviously)
Torque converter from Xterra trans (most places include this but make sure)
If it is from a supercharged you'll need the flywheel as well
Need to reuse the r50 sub-harness as it is the proper length
Some extra vacuum line for the vent hoses
It is plug and play. I have an 02 or 04 SC xterra transmission in my 1994 pathfinder. Has been in there since 2013.
You will need:
thank you very much!
