Caliper slide pins rubber boot and bolt 02 4wd pathfinder question
Petercan1020
I have an 02 Nissan Pathfinder and I'm putting on new brakes and decided to change the caliper pins on both sides cuz it didn't look like any of them matched does anybody know on this year 2002 Pathfinder if the rubber boot is in the top slide position of the caliper or the bottom position of the caliper I can't find a straight answer
I just needed to know what side the inner rubber ring on the caliper pins there's one on each side one ring for every two pins I was reading different things some people saying bottom some people saying top I was just looking to see which was correct and couldn't find a straight answer I wasn't talking about the two outer boots that you can see just the one that goes on the slide pin inside the caliper 1 per side thank you
