Petercan1020 Posted August 26, 2017 Share Posted August 26, 2017 I have an 02 Nissan Pathfinder and I'm putting on new brakes and decided to change the caliper pins on both sides cuz it didn't look like any of them matched does anybody know on this year 2002 Pathfinder if the rubber boot is in the top slide position of the caliper or the bottom position of the caliper I can't find a straight answer Link to comment Share on other sites More sharing options...
ChemExposure Posted August 27, 2017 Share Posted August 27, 2017 Do you mean the one with the rubber ring on the inside? That's the top one.Otherwise all 4 of them all have the same rubber boots.Just buy the slider pin kit for a Pathfinder from an auto parts store. Link to comment Share on other sites More sharing options...
Petercan1020 Posted August 28, 2017 Author Share Posted August 28, 2017 Yes im speaking about the boot that slides inside the caliper there's one on each side not the two boots on the outside that you can see Link to comment Share on other sites More sharing options...
Petercan1020 Posted August 28, 2017 Author Share Posted August 28, 2017 I just needed to know what side the inner rubber ring on the caliper pins there's one on each side one ring for every two pins I was reading different things some people saying bottom some people saying top I was just looking to see which was correct and couldn't find a straight answer I wasn't talking about the two outer boots that you can see just the one that goes on the slide pin inside the caliper 1 per side thank you Link to comment Share on other sites More sharing options...
Exorpmtech Posted August 28, 2017 Share Posted August 28, 2017 The little rubber tube usually goes on the bottom. I belive its an 'anti-rattle' device. Link to comment Share on other sites More sharing options...
Petercan1020 Posted August 28, 2017 Author Share Posted August 28, 2017 This is what i mean i get both answers i know on 2011 its the bottom i need a definite answer and cant find it ty though Link to comment Share on other sites More sharing options...
Bax03SE Posted August 28, 2017 Share Posted August 28, 2017 I have no idea where they originally were from the factory, but on mine they're on the bottom. Based on the mixed responses, it sounds like it doesn't really matter. Link to comment Share on other sites More sharing options...
Citron Posted August 28, 2017 Share Posted August 28, 2017 If you looked on the parts diagram on any of the dealerships parts stores, like courtesy Nissan, it should show where the peice belongs. Link to comment Share on other sites More sharing options...
Petercan1020 Posted August 29, 2017 Author Share Posted August 29, 2017 I looked found nothing Link to comment Share on other sites More sharing options...
ChemExposure Posted August 29, 2017 Share Posted August 29, 2017 Mine was definitely on the top. Just take yours out to find out, they're slider pins. Should slide easy lol.Check the brake section of the factory service manual. Everything you probably need to see is in there. Link to comment Share on other sites More sharing options...
neilca Posted August 29, 2017 Share Posted August 29, 2017 My calipers have two boots per side. I just bought one of these kits to replace them http://www.ebay.com/itm/Disc-Brake-Caliper-Bushing-Front-Rear-Better-Brake-16043-/222439068811?epid=76090573&hash=item33ca66d48b:g:XrwAAOSw9~5ZOj~R&vxp=mtr Link to comment Share on other sites More sharing options...
