KILLANOLA Posted June 23, 2016 Share Posted June 23, 2016 What is the best way to bypass the clutch safety switch besides sadering? My mechanic said it was going out and he can't bypass it. Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted June 23, 2016 Share Posted June 23, 2016 You could spend 20 bucks to replace it? Or pull one at a junkyard and put it in. But if you really need to by pass it you can cut the wires off the plug and butt splice them together. 1 Link to comment Share on other sites More sharing options...
KILLANOLA Posted June 24, 2016 Author Share Posted June 24, 2016 I had replaced it and 3 months later it's going out again. Could something else be causing it to go out? Or I got a bad part? Link to comment Share on other sites More sharing options...
NP670 Posted June 24, 2016 Share Posted June 24, 2016 (edited) Yup, PathyAndTheJets is right. Its the only solution. Possible it might be a bad switch too. Sent from my SM-N910T using Tapatalk Edited June 24, 2016 by NP670 Link to comment Share on other sites More sharing options...
adamzan Posted June 24, 2016 Share Posted June 24, 2016 (edited) Perhaps the clutch switch is not the issue...Check the connections to the starter, does it have a remote start or aftermarket alarm installed? Check that too. And did you mean soldering? Sorry but bad spelling really bothers me, especially when even your phone has a spell checker. Edited June 24, 2016 by adamzan 1 Link to comment Share on other sites More sharing options...
KILLANOLA Posted June 28, 2016 Author Share Posted June 28, 2016 Sorry adamzz I wasn't using my phone. I noticed you edited your post for ?? Was it spelling or the run on sentence. Wait no the run on sentence is still there. lol Really Dad no grammar lesson from you But back to the issue. I still cant seem to get the switch off? does it have 2 releases? There is only one side showing. Does the clutch safety switch screw into the metal brace? Link to comment Share on other sites More sharing options...
NP670 Posted July 8, 2016 Share Posted July 8, 2016 (edited) Yes, it screws on to the bracket and its just one...I will be changing mine and I'll just use a momentary push button switch Sent from my SM-N910T using Tapatalk Edited July 8, 2016 by NP670 Link to comment Share on other sites More sharing options...
5523Pathfinder Posted July 9, 2016 Share Posted July 9, 2016 Are you sure it's not the inhibitor realy? Big blue realy next to the battery. Link to comment Share on other sites More sharing options...
ahardb0dy Posted July 9, 2016 Share Posted July 9, 2016 (edited) The clutch safety switch just provides a ground to the starter relay under the hood. Easiest way to bypass the switch would be to disconnect the wire coming from the switch at the relay and run a new wire from a ground to the spot on the relay where you disconnected the wire. If your having problems with the truck is starting, the starter relay is a common item to fail. Edited July 9, 2016 by ahardb0dy Link to comment Share on other sites More sharing options...
