02 pathfinder v6. Ran out of gas n now won't start.
Sjjackson
When I replaced the injectors on my Maxima, afterward it wouldn't start until I depressed the accelerator about half way and cranked a few times. It was like the system was air locked but the ECU wasn't smart enough to realize it.
Sent from my Nexus 5X using Tapatalk
Since the fuel pump was the last thing you worked on, I would check that first. Check the fuel pump fuse, check for voltage at the fuel pump connector, check for voltage at the fuel pump relay.
Came out today, truck started and died, wouldn't restart. Replaced fuel filter. Started, run for a minute and died again. Now it won't start. Running out of ideas.
