92 wd21 v6 vac lines
TwoScoops
Here it is with the length (L=mm) in millimetres. Just cut your hose to fit.
There are some there where the length isn't listed because they were a part from Nissan and were formed with a bend. If those are rotted as well then just give yourself some more length on the line so it doesn't kink up.
Cool...glad that helped. Its a better diagram than the one in the FSM that you should also have as a reference for other work you will end up doing.
I have to give credit to Akorhill aka Rob who was kind enough to share that document.
FYI - There is No Vacuum diagram attached to the underside of the hood. Just the standard info specs about the engine.
It's weird, I have seen some with the diagram under the hood. Maybe the ones without it have been replaced.
Most cars come with one for emissions testing and inspection.
Sent from my SM-G920V using Tapatalk
