TwoScoops Posted November 9, 2015 Share Posted November 9, 2015 I have a repair manual but cant seem to locate a good vac line diagram. can someone help me out? google is too hit and miss ...... but mostly miss. Link to comment Share on other sites More sharing options...
SpecialWarr Posted November 9, 2015 Share Posted November 9, 2015 The vacuum line diagram is supposed to be attached to the underside of the hood, not that mine is any help since my hood is a replacement. Link to comment Share on other sites More sharing options...
Pav Posted November 9, 2015 Share Posted November 9, 2015 Here it is with the length (L=mm) in millimetres. Just cut your hose to fit. There are some there where the length isn't listed because they were a part from Nissan and were formed with a bend. If those are rotted as well then just give yourself some more length on the line so it doesn't kink up. Link to comment Share on other sites More sharing options...
TwoScoops Posted November 9, 2015 Author Share Posted November 9, 2015 That's exactly what I needed. Thanks Link to comment Share on other sites More sharing options...
Pav Posted November 10, 2015 Share Posted November 10, 2015 Cool...glad that helped. Its a better diagram than the one in the FSM that you should also have as a reference for other work you will end up doing. I have to give credit to Akorhill aka Rob who was kind enough to share that document. FYI - There is No Vacuum diagram attached to the underside of the hood. Just the standard info specs about the engine. Link to comment Share on other sites More sharing options...
SpecialWarr Posted November 11, 2015 Share Posted November 11, 2015 Whaaaaatttt!!! Maybe it's just the german cars that do that. All of my VWs had one glued onto the hood ( except the beetle which didn't have a hood.... or a panel... or a windshield! Thanks Pav!! Link to comment Share on other sites More sharing options...
adamzan Posted November 11, 2015 Share Posted November 11, 2015 Cool...glad that helped. Its a better diagram than the one in the FSM that you should also have as a reference for other work you will end up doing. I have to give credit to Akorhill aka Rob who was kind enough to share that document. FYI - There is No Vacuum diagram attached to the underside of the hood. Just the standard info specs about the engine. It's weird, I have seen some with the diagram under the hood. Maybe the ones without it have been replaced. Link to comment Share on other sites More sharing options...
mechanicalbaron Posted November 11, 2015 Share Posted November 11, 2015 Cool...glad that helped. Its a better diagram than the one in the FSM that you should also have as a reference for other work you will end up doing. I have to give credit to Akorhill aka Rob who was kind enough to share that document. FYI - There is No Vacuum diagram attached to the underside of the hood. Just the standard info specs about the engine. Most cars come with one for emissions testing and inspection. Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
