Identifying Xterra transmissions
gutbusterman
Hi all. I bought a 95 Pathy 4x4 XE about 2 months ago, and of course the tranny pooped out after noticing reverse was a little delayed. I have read on here Xterra transmissions swap right in. I found an awesome deal (I hope) locally, 160k mile Xterra trans, fluid looks good. But, I don't know how to identify the transmission. I did find a tag that says:
JATCO CORP
4FX01
3720772
A little search on the google shows it as an old part number for the trans/transfer case unit but no ID otherwise.
Any thoughts?
As long as it is any xterra trans it will be fine. If it ends up being out of a supercharged, you need the flexplate (flywheel) from the SC motor as the bolt pattern for the Torque converter is different.
  • 3 months later...
The tcm is separate from the ecu. You will probably need to check the wiring and see if yours is a 3 speed or 4 speed. I'm not familiar with the older model pathfinder transmission.
Sent from my SAMSUNG-SM-N920A using Tapatalk
