Bent my trailing arms-Heavy duty lower trailing arm options?
NovaPath
So while underneath my truck today it appears I have bent not one but both of my rear trailing arms on rocks from one of my recent off road trips. A quick google search indicates that rugged rocks off road offers an HD option, but it seems a bit pricey for my current financial situation(broke). I'm wondering if anyone has retrofitted any other lower control arms into these rigs? In theory it is just a couple of bolts connecting a long piece of metal, as long as the length can be made the same it should be plug and play I would think. I'm not interested in going with new OEM equivalents as I'm sure within six months I will have managed to bend those up as well..
Thanks for the help!
-Ryan
Edited by NovaPath
Fluerys use to make an option, but lack of sales and his Un happy results on his rig cause him to stop production. So unless you want to develop something of your own, your kinda stuck. But how hard could it be? For you're needs you just need some square tubing and some tubing that's the same as the stock bushings, weld it on at each ends and boom super strong lowers which is all you need.
-Kyle
Thats my thinking too Kyle, problem is I can't weld :blush02: . Why are you thinking square as opposed to round, would square tubing be more resistant to bending? There is a fabricator that sponsor's my local club, I keep meaning to give him a call to ask him about this and just haven't done it yet..
You could even re-use the ends of the oem ones and just weld (or have welded) a stronger mid section in place. I'm fleurting with the idea too, as well as add an inch to it. I'm on WJ coils and they likely won't get compressed all the way very often and if they do, there would still be room for the wheel to tuck, just like there is room for it to move forwards. But at least for the majority of regular driving it would sit back in the centre.
Let me know how you make out.
I would think round is stronger than square, for the same reason submarines are round, not square.
That's actually very clever, simple, cheap and effective.
Btw. How have those poly bushings help up? Mine are finally blown in the rear and I'm running through my options, I really like the "set and forget" of rubber/stock but the durably of Poly, but don't they need to be greased periodically? And I've heard they ride a little stiffer, is that true?
Hate to thread jack. Pm xplorer if you would be so kind. Thanks.
-Kyle
Adding strength is an interesting consideration. since the stock arms are hollow, what if you cut them in half at the middle, and got a thicker, stronger steel tube the exact right diameter to fit inside. then slide the 2 ends over it and weld it up. you could add length this way too, if you choose.
^^ I like this idea, however it sounds a lot more complicated than the other option of simply welding on armour. XplorX used a triangle shaped design. You could also take a 1/2 square tube and weld the entire arm in it, leaving the top open for the welds.
That's true, I think I may do both. I have new lca's with poly bushes sitting in the shed, I never want to have to deal with bent arms. If I do it, I will take lots of pics!
Here`s a new model, cheaper that I have done... I ended up removing them because of the bushing having a bad design. But for the core structure, these are pretty much full proof. Made from 3/16'' 2x2 square tube. Fully welded and powder coated.. This is a new model that will hopefully sell better than my high end aluminum ones I use to make.
Here`s one more idea for you...
Edited by fleurys
I bought a pair of OEM arms and had pieces of angle-iron welded to them. They have held up to some pretty extensive abuse ever since.
https://www.dropbox.com/s/u1fqm38dparmofh/lca1.jpg?dl=0
Interesting Idea! I was actually laying in bed last night wondering If I could do something similar but without the welding, and use some 1/4 inch thick angle iron and some U-bolts...
I call dibs on testing!
Any plans for making adjustable ones again? I know there are few guys who want or adjust the rear axle location after a lift.
G
I'm closer! lol
I would definitely be interested in an adjustable set, or simply a set that's an inch longer and centres the wheels again.
Are these hollow Steve?
U-bolts won't really work, because they'll get caught on whatever the arm drags over and will get pulled off. (Landing on or dragging over something is why trailing arms get bent.)
Also, the increased strength comes from attaching [welding] the angle-iron along the entire length of the arm, not only at two ends.
Those are the problems I ran into in my head last night, too..ha ha. I was thinking about using multiple(like 6) and having the ubolts on the top with a slightly larger angle bracket with holes drilled...at any rate it doesn't matter too much work and I'm sure it would break. I'll look into the angle bracket and welding idea, though. Just have to find someone willing to weld them for me...
If anyone has a bent or otherwise junk lower trailing arm, would you be willing to cut it in half to verify that it is completely hollow, and measure the inside diameter of the arm? It would be greatly appreciated!
G
Adjustable ones are a pain to make so that they do not loosen on the trail and also the cost becomes prohibitive for customers.. Steevo from rugged has one set available and believe me at the price he sells them, he's not making alot of profit... That's one reason i'm not planning on doing them anymore.. Like I showed, I will be doing more of a fixed length (with possibly taking custom length order).
I'm closer! lol
yes they are hollow . 3/16" thick.
If you use a single triangular upper, the panhard bar goes in the trash. Now your rear end stays paerfectly centered and you can calculate cramming tires without guesswork too. I live in texas so we never consider corrosion here. But id make up some killer stainless bars if i lived in a salt and rust state...hmmm
Sent from my LGMS395 using Tapatalk
So here is the question now, what would be stronger:
1. The rugged rocks offroad DOM links : https://ruggedrocksoffroad.com/hd-adjustable-lower-rear-suspension-links-nissan-pathfinder-1996-2004-by-rugged-rocks-p-3885.html?osCsid=64fk61qgt5ks4mbdlganbc6fp0
-Or-
2. Stock links with poly bushings and angle iron welded to the bottom?
Price difference is going to be within 100.00, with the slightly cheaper one being the angle iron option...
Thoughts?
