Brake pads
Just avoid the cheap 20 dollar pad sets and you should be fine. I am thinking about going with the Hawk pads next time around. I usually just use the Monroe stuff because it works great, doesn't make noise, and is reasonably priced (about $50 a set locally).
so far have new ebc rotors and new Hawk OES pads on the front. the braking power seem to have improved. I really like on how well their working so far. and I would suggest them to other people. but keep in mind replacing the rotors on the front of the pathfinders are a little difficult at first if you have never done them before.
so far the rotors where ( EBC Brake Rotors - Ultimax OE Style Disc Kit (RK620)
and the brake pads. ( Hawk OES (Original Equipment Service) Brake Pads (770333)
the rotors are a little pricey but seem to work well even in high heat loads.
