t belt whining, will go away right ?
just finshed tbelt replace. the belt whining , i can barely hear it ( without fan) at idle, when i give gas and rpm come back down , it sounds like a turbo spooling down. so i guess the a little too much tension. my question is will it be ok/ , does it need time to break in? the sound does not brother me , i just want to be reassured it ok.
I agree with Adam, a little noise shouldn't hurt anything as the belt will stretch slightly. I helped with a timing belt on an inlaws R50 and it whined a little at first as well.
I believe K9sar went to the other extreme where his was so tight it broke the tensioner bolt? Been a while...
lol i.e. damn dyslexia
:lol:
Mine had a fairly audible whine that went away after a couple of weeks of regular driving. They should put a notice/warning ticket for this in the original timing belt packaging.
It depends how loud. Done correctly it will not whine. If it is too tight it will snap a cam or prematurely wear out the tensioner bearing. If it is very slight run it
