APACHECHIEF13 Posted April 11, 2014 Share Posted April 11, 2014 Has anyone replaced the rack and pinion gears in the front end out of 87 wd21? How hard is it to do? I have about 1/8 play in the front diff where the front drive shaft is. I found a rack and pinion set for 315 but I have another 88 pathy with the same gears. should I just sway the whole axle housing or just buy a new set Link to comment Share on other sites More sharing options...
92Path_68CJ Posted April 11, 2014 Share Posted April 11, 2014 Do you mean ring and pinion? The gear that goes in the front differential? Link to comment Share on other sites More sharing options...
APACHECHIEF13 Posted April 11, 2014 Author Share Posted April 11, 2014 yes miss print lol I'm so dumb. Ring and Pinion needs replaced 1/8 play is it easy for someone that has not done it before. Link to comment Share on other sites More sharing options...
SteeevO Posted April 12, 2014 Share Posted April 12, 2014 an 1/8" play where? Link to comment Share on other sites More sharing options...
APACHECHIEF13 Posted April 14, 2014 Author Share Posted April 14, 2014 In my pinion. I need to rebuild my front diff till then I'll blow it up or try and us the other one I have out of my 88 pathy. I really don't want to tear it a apart but I will have to soon. Link to comment Share on other sites More sharing options...
APACHECHIEF13 Posted April 14, 2014 Author Share Posted April 14, 2014 I found new set of front diff ring and pinion for 300 and 300 for the rear. I just don't have any money right now Link to comment Share on other sites More sharing options...
Slartibartfast Posted April 15, 2014 Share Posted April 15, 2014 Back and forth or turning? If the gear ratio in your other rig is the same, it should bolt right in and work fine. If the ratio's wrong, a wrecking yard might sell you a diff for less than you could get those gears for. Link to comment Share on other sites More sharing options...
APACHECHIEF13 Posted April 15, 2014 Author Share Posted April 15, 2014 There the same just a lot of work dame ifs lol Sent from my Z795G using Tapatalk Link to comment Share on other sites More sharing options...
Nefarious Posted May 15, 2014 Share Posted May 15, 2014 It's easy to pull out, not as easy to put back in. It's actually less work to swap the one from your other truck over...but... why do you say it needs replacing? Does it make any noise or otherwise drive improperly? A tiny bit of rotational play in yhe driveshaft likely wont ruin your day if its that small and you don't have any other issues? Link to comment Share on other sites More sharing options...
APACHECHIEF13 Posted May 16, 2014 Author Share Posted May 16, 2014 Just some play in the ping and pinion where the front drive shaft meets. 1/4 play but drives fine and no noise, grinding, or problems with it just the play in it that's all. Sent from my Z795G using Tapatalk Link to comment Share on other sites More sharing options...
