v30 wont start when hot
mikey_nz
hey guys i have recently got a pathfinder. it is a 91 v30 petrol 5 speed.
when it is cold it starts first turn of the key, once the engine is warmed up it will not start.. cranks over but thats all. i had a few guys help me try push start it and it started but was missing all the way home.
i need some help plz guys
mike
It is the one for the ECU, in the top jacket by the thermostat. If the two, I believe it is the rearward one, with a yellow body I think.
We accidentally interrupted the wiring connection for it on a friends Pathfinder and were talking as it warmed up idling. The motor suddenly cut out as if the ignition was turned off and it refused to start until we fixed the connector, then it ran fine. Try just wiggling/cleaning the connector first, then you can check the resistance of the sensor using the values you can find in the Factory Sercive Manual you can download from the Garage section.
I hate just changing parts without testing the old one if possible. :shrug:
