ahardb0dy Posted September 22, 2013 Share Posted September 22, 2013 Do the newer ( newer than WD21) pathfinders have a rear cargo cover and if so will it work in a WD21 with modification? Link to comment Share on other sites More sharing options...
RF600 Posted September 24, 2013 Share Posted September 24, 2013 I believe they will work. Yes there will be modifications. I want to do it. I know that you will need a spot weld cutter to take the brackets off and re-weld them to the body. I think the bezel around the bracket is removable, off of the donor vehicle, not sure. I have not found a suitable donor yet. Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 24, 2013 Author Share Posted September 24, 2013 I found one at the junkyard last weekend, well I saw the brackets the cover was gone, and saw how they were, the front brackets are like recessed into the panel, I'm sure they could be mounted somehow into the WD21. Problem will be finding the cover part. Need to replace my hooptie fabric, 2 broom handle cover I made Link to comment Share on other sites More sharing options...
Precise1 Posted September 24, 2013 Share Posted September 24, 2013 I have to dig around in the pathfinders today, so I'll do some basic measurements to make sure it can fit or not. Yes, there would probably be some cutting involved... B Link to comment Share on other sites More sharing options...
Alkorahil Posted September 24, 2013 Share Posted September 24, 2013 I dont think one from a 2013 will be long enough..... Link to comment Share on other sites More sharing options...
Precise1 Posted September 25, 2013 Share Posted September 25, 2013 Ok, one from a 1999.0 R50 is 25" deep, 55" wide at rear most clip, 58" wide forward. A WD21 is more like 52" rear and 55", 25" forward of thatNot that it couldn't be done, but a universal aftermarket might be just as cheap/easy. B Link to comment Share on other sites More sharing options...
