filling in the holes...
captandy
I was an auto body tech for years and the correct way to fill those holes is to fill with a welder.You grind around the hole and inside the hole down to metal.Get your small metal pieces cut out.You hold the metal behind the hole and tack it and slowly fill the hole in and grind it back down smooth as possible and use body filler over each hole when your done.Then sand smooth and primer undercoat the rear.Take your time filling in with the welder or your panel will get too hot and warp your metal then you have more of a problem.Good Luck! Your Pathfinder looks Great!! Nice Ride!
