captandy Posted September 19, 2013 Share Posted September 19, 2013 Decided to remove fender flares.. gonna paint whole truck pearl white with black lower section.. just a matter of time before i snapp em off offroad.Any ideas from you guys? Link to comment Share on other sites More sharing options...
Leo94 Posted September 19, 2013 Share Posted September 19, 2013 I would use something like fiberglass filler or JB weld. Link to comment Share on other sites More sharing options...
Karmann Posted September 19, 2013 Share Posted September 19, 2013 Likewise- Some sort of filler. You may be able to get the lines on the paint out with a good rubbing compound like Meguiar's Ultimate Compound too. Link to comment Share on other sites More sharing options...
Leo94 Posted September 19, 2013 Share Posted September 19, 2013 Also don't use regular body filler, that's just for smaller stuff and may even come out after a couple of offroading trips. Link to comment Share on other sites More sharing options...
XPLORx4 Posted September 19, 2013 Share Posted September 19, 2013 Follow this basic concept: Link to comment Share on other sites More sharing options...
borninabarn Posted September 19, 2013 Share Posted September 19, 2013 I was an auto body tech for years and the correct way to fill those holes is to fill with a welder.You grind around the hole and inside the hole down to metal.Get your small metal pieces cut out.You hold the metal behind the hole and tack it and slowly fill the hole in and grind it back down smooth as possible and use body filler over each hole when your done.Then sand smooth and primer undercoat the rear.Take your time filling in with the welder or your panel will get too hot and warp your metal then you have more of a problem.Good Luck! Your Pathfinder looks Great!! Nice Ride! 1 Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted September 19, 2013 Share Posted September 19, 2013 I don't know why you pulled em...but if you fill them, I 2nd borninabarn. Weld is the only way to do it. If you use body filler, it will crack your paint eventually and rust. Lots of experience on VW beetles. Link to comment Share on other sites More sharing options...
captandy Posted September 20, 2013 Author Share Posted September 20, 2013 thanks guys.. Link to comment Share on other sites More sharing options...
theexbrit Posted September 20, 2013 Share Posted September 20, 2013 If you want the "Steampunk" look, you can use door panel clips :laugh: 1 Link to comment Share on other sites More sharing options...
Precise1 Posted September 20, 2013 Share Posted September 20, 2013 ^Exactly what I was going to say! Fill the holes with clips/plugs and call it good... B 1 Link to comment Share on other sites More sharing options...
captandy Posted September 20, 2013 Author Share Posted September 20, 2013 i like it and thats what im gonna do... semi totally rigged cheap custom!! 2 Link to comment Share on other sites More sharing options...
Precise1 Posted September 21, 2013 Share Posted September 21, 2013 LOL, KISS! The black will look good against the gray... B Link to comment Share on other sites More sharing options...
theexbrit Posted September 21, 2013 Share Posted September 21, 2013 LOL, KISS! The black will look good against the gray... B Get a little mud on there, no one will ever notice! Actually it might look pretty cool on gray. Link to comment Share on other sites More sharing options...
