92Path_68CJ Posted April 24, 2013 Share Posted April 24, 2013 Nice Titan. Link to comment Share on other sites More sharing options...
Nefarious Posted May 1, 2013 Share Posted May 1, 2013 sick truck man. that thing is beast. Link to comment Share on other sites More sharing options...
BIGFINDERMAN Posted May 1, 2013 Author Share Posted May 1, 2013 Thanks guys! I havn't had much time to work on her. I did take it down the road the other day. Steering is a little squirley, which some of that may be do the the terrible road i live on back in the sticks. I need to tune on my toe settings a little. Link to comment Share on other sites More sharing options...
BIGFINDERMAN Posted May 2, 2013 Author Share Posted May 2, 2013 I seem to have some negative camber going on on the driver side front. I know i did not bend the c's when i knocked them off and im pretty sure they were square when i welded them back on. Thoughts? Link to comment Share on other sites More sharing options...
stalker Posted May 4, 2013 Share Posted May 4, 2013 Either bend or welded back on off square..?? Hard to determine without being there with you looking at it...? Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 4, 2013 Share Posted May 4, 2013 I would say it was just a hair out of square before the welding they are pretty hard to bend them I would look around for some spindle shims or get a ball joint shim to fix it up! I have spindle shims out in the garage I think if you need one Link to comment Share on other sites More sharing options...
enkrypt3d Posted May 5, 2013 Share Posted May 5, 2013 dumb question but how does the front solid axle connect to the hubs to allow for steering w/o having to use CV axles? Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 5, 2013 Share Posted May 5, 2013 There is axle shafts that connect to the hubs and run into gears that the drive line connects to just like the ifs and then there is a drag link that runs to a steering arm on the passenger knuckle and both knuckles are connected by the tie-rod If it dont go chrome it! Link to comment Share on other sites More sharing options...
enkrypt3d Posted May 5, 2013 Share Posted May 5, 2013 (edited) right but how does the axle provide power while it rotates? any pics of these gears? I'm trying to visualize it ... thx and great build! now go get some knobby ass tires! lol < to the OP Edited May 5, 2013 by enkrypt3d Link to comment Share on other sites More sharing options...
stalker Posted May 5, 2013 Share Posted May 5, 2013 right but how does the axle provide power while it rotates? Ummmm....nismo you should have explained it better C'mon man...lol Link to comment Share on other sites More sharing options...
enkrypt3d Posted May 5, 2013 Share Posted May 5, 2013 (edited) Ummmm....nismo you should have explained it better C'mon man...lol lol no worries i should have said while turning the steering wheel.... which IMO would be the weakest link... unless all you SAS guys dont need to turn the steering wheel and just haul all over anything in your way lol Edited May 5, 2013 by enkrypt3d Link to comment Share on other sites More sharing options...
BIGFINDERMAN Posted May 6, 2013 Author Share Posted May 6, 2013 I was pretty sure they were square when i welded them back on. Im sure it would be easy for one to get off square though. According to an angle finder on the hub, it is about 1 degree negative. Would an adjustable ball joint or spindle shim be better to use? Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 7, 2013 Share Posted May 7, 2013 I was pretty sure they were square when i welded them back on. Im sure it would be easy for one to get off square though. According to an angle finder on the hub, it is about 1 degree negative. Would an adjustable ball joint or spindle shim be better to use? The spindle shims a re better but if its only one degree i think i run the ball joint cuz it can kind of be adjusted. Ummmm....nismo you should have explained it better C'mon man...lollol no worries i should have said while turning the steering wheel.... which IMO would be the weakest link... unless all you SAS guys dont need to turn the steering wheel and just haul all over anything in your way lolThe steering box runs the same way it used to just with a drag link bolted to it instead of the centerlink and the drag link like i said before goes from steering box to the passenger knuckle and the passenger knuckle is connected to the drivers side via the tie-rod!If it dont go chrome it! Link to comment Share on other sites More sharing options...
enkrypt3d Posted May 7, 2013 Share Posted May 7, 2013 The spindle shims a re better but if its only one degree i think i run the ball joint cuz it can kind of be adjusted. The steering box runs the same way it used to just with a drag link bolted to it instead of the centerlink and the drag link like i said before goes from steering box to the passenger knuckle and the passenger knuckle is connected to the drivers side via the tie-rod! If it dont go chrome it! Wasn't talking about the steering linkages...... I'm wondering how the axle (if its really solid like the rear) can flex while steering w/o having CV axles......... Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 7, 2013 Share Posted May 7, 2013 Its got u-joints like a drive shaft at the knuckles that allow it to turn its nothing like a rear end! Have you never looked at an old ford chevy dodge or jeep before? Link to comment Share on other sites More sharing options...
stalker Posted May 7, 2013 Share Posted May 7, 2013 Its got u-joints like a drive shaft at the knuckles that allow it to turn its nothing like a rear end! Have you never looked at an old ford chevy dodge or jeep before? Nice looking Axle...wha cha got going on there bud.!? Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 7, 2013 Share Posted May 7, 2013 Its got u-joints like a drive shaft at the knuckles that allow it to turn its nothing like a rear end! Have you never looked at an old ford chevy dodge or jeep before?That is the hp 44 minus 3 from the long side for the frontier that i am doing the swap on this weekend its loaded with 4.88s and an eaton E-locker!Nice looking Axle...wha cha got going on there bud.!?If it dont go chrome it! Link to comment Share on other sites More sharing options...
BIGFINDERMAN Posted May 7, 2013 Author Share Posted May 7, 2013 Did some more research on the camber last night. Put it on jackstands at ride height and put an angle finder on the rotors. Doesnt make alot of since now. Axle is level and both sides are pretty much dead nuts on. Here are a few pics. Link to comment Share on other sites More sharing options...
stalker Posted May 7, 2013 Share Posted May 7, 2013 WTF...yea that's strange.... Link to comment Share on other sites More sharing options...
stalker Posted May 7, 2013 Share Posted May 7, 2013 YO...What's up with the Jeep Bro.!! Link to comment Share on other sites More sharing options...
stalker Posted May 7, 2013 Share Posted May 7, 2013 im saying its a Ball joint issue...Shims should take care of that Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 8, 2013 Share Posted May 8, 2013 The other thing i am thinking is tweaked knuckle? I crashed a truck once and it bent the outter and looked fine bolted up fine but bent it some way it drove like @!*% If it dont go chrome it! Link to comment Share on other sites More sharing options...
BIGFINDERMAN Posted May 8, 2013 Author Share Posted May 8, 2013 That's my boys old ride. He has a John Deere gator now that he calls his little pathfinder! YO...What's up with the Jeep Bro.!! 1 Link to comment Share on other sites More sharing options...
BIGFINDERMAN Posted May 8, 2013 Author Share Posted May 8, 2013 I re torqued everything last night and set my toe to about 1/16 toe in. It looks right now. I know when i first assembled everything back together, i did not torque the preload bushing. And i probably spun it from its original position. Guess that was my problem. I still might swing by the alignment shop and get some numbers on everything. Link to comment Share on other sites More sharing options...
nismopathy93 Posted May 8, 2013 Share Posted May 8, 2013 Well thats good glad to hear that! If it dont go chrome it! Link to comment Share on other sites More sharing options...
