6 Lug bolt pattern
dirtx
To get some toyota wheels to fit on a nissan, you'll need to switch lug type and it can be a complete ball ache trying to find nuts with the correct shank to match nissans m12 1.25 thread.
Also, some toyota are hub centric and not lug centric, which is something else to consider when some toyota are 108mm centre bore and pathfinders 100mm..
It's all solvable though :shiftyeyes:
edit- toyota might be 112mm actually? definitely not 100mm anyway.
Edited by 3rdtimesacharm
member 'shasdakota' is the first one that comes to my mind that located the other style lugs needed for some toyota wheels, he runs (last time I remember seeing him on here at least) the aluminum SR5 wheels off a 90's 4x4 Toyota on his wd21
and had to locate the 'tophat' style shanked lugs. If thats what you plan on running, I would send him a pm (or I can for you if you wish) and see if he has a part number/store name he got them from in the correct thread :aok:
thanks for all the info, looks like i need new lug nuts. If i get them il shoot top hat a pm. I put those same toyota wheels on my old isuzu pup. they fit perfect. thanks again.
