davidakil85 Posted January 31, 2013 Share Posted January 31, 2013 I HAVE A PATHFINDER 96 MY RATIO FRON RING AND PINION IS 4,88 WITH TIRES 31 INCHES BUT THE CAR IS SLOW IN CLIMS WHAT RADIO I NEED FOR MORE POWER AND PUT THE 33 TIRES???? PLEASE YOUR HELP Link to comment Share on other sites More sharing options...
92Path_68CJ Posted January 31, 2013 Share Posted January 31, 2013 Hmmm, I normally suggest 4.56 gears for 33s. Pathfinders must be more different than I thought... Maybe 5.13? Probably need a bigger jump than that. Link to comment Share on other sites More sharing options...
kiwipete Posted January 31, 2013 Share Posted January 31, 2013 Mine is a '95 TD27 auto with 33's and I have 4.88 gears. I have no problems with this combo. Link to comment Share on other sites More sharing options...
davidakil85 Posted January 31, 2013 Author Share Posted January 31, 2013 but i have the ratio 4.88 with tire 31,s but in climb is too slow??? Link to comment Share on other sites More sharing options...
kiwipete Posted January 31, 2013 Share Posted January 31, 2013 but i have the ratio 4.88 with tire 31,s but in climb is too slow??? Are you using low ratio gearing? Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 31, 2013 Share Posted January 31, 2013 Maybe clean your intake and check your vac lines/MAF/TPS, maybe it's down on power. Link to comment Share on other sites More sharing options...
Precise1 Posted February 1, 2013 Share Posted February 1, 2013 Cleaned up the title... B Link to comment Share on other sites More sharing options...
davidakil85 Posted February 1, 2013 Author Share Posted February 1, 2013 noup the engine and the componets are highly Link to comment Share on other sites More sharing options...
pathybuilder Posted February 1, 2013 Share Posted February 1, 2013 I see in your profile, you have listed Z24 in your info section. Does this mean you're running a 4 cyl engine, rather than the V6 VG30E. If this is the case, gears will only help you so much. Link to comment Share on other sites More sharing options...
