andreus009 Posted January 26, 2013 Author Share Posted January 26, 2013 Just checked my LUK flywheel. Same as the one you have pictured on the right. Link to comment Share on other sites More sharing options...
92Path_68CJ Posted January 26, 2013 Share Posted January 26, 2013 Then yes, you need the weight, good luck man. 1 Link to comment Share on other sites More sharing options...
MY1PATH Posted January 26, 2013 Share Posted January 26, 2013 Then yes, you need the weight, good luck man. Also, these are the kind of hills where I noticed the difference... Seattle and San Francisco alike, everything else is not so bad. Link to comment Share on other sites More sharing options...
Tungsten Posted January 27, 2013 Share Posted January 27, 2013 Are those balancing holes too? The OEM Nissan flywheel is better for sure. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 27, 2013 Share Posted January 27, 2013 Are those balancing holes too? The OEM Nissan flywheel is better for sure. yes, the heavier flywheels had enough material to be balanced on the engine side. Lighter ones are balanced too, smaller holes on the clutch side. they are inline with the threaded holes for the clutch cover. Link to comment Share on other sites More sharing options...
MY1PATH Posted February 4, 2013 Share Posted February 4, 2013 (edited) So here is my USED OEM D22 Frontier flywheel all cleaned up. It started off at 24.6 and ended at 24.2 once it was all cleaned up and hard spots removed...0.20" was machined off of it to get all the hard spots off and all the rust was sandblasted off the back side. It Lost about 6 oz doing all this. Edited February 4, 2013 by MY1PATH Link to comment Share on other sites More sharing options...
Leo94 Posted February 4, 2013 Share Posted February 4, 2013 24.2 Great find. Link to comment Share on other sites More sharing options...
Precise1 Posted February 4, 2013 Share Posted February 4, 2013 0.20" was machined off of it to get all the hard spots off and all the rust was sandblasted off the back side. It Lost about 6 oz doing all this. Are you sure you don't mean .02"? B Link to comment Share on other sites More sharing options...
MY1PATH Posted February 4, 2013 Share Posted February 4, 2013 Are you sure you don't mean .02"? B i miss zeros when I'm falling asleep. can you fix it? Link to comment Share on other sites More sharing options...
Precise1 Posted February 4, 2013 Share Posted February 4, 2013 Done. I'll delete these posts tonight. B 1 Link to comment Share on other sites More sharing options...
