Door Open?
Imorales321
Hey guys, I'm new to the forum and have already gained a lot of information about my 95 Pathy, so thanks! My pathfinder has the door open light on and I'm pretty sure all the doors are closed. I've already done multiple sweeps around opening and closing all the doors. Could this be anything else or have you had the same problem? I definitely don't wanna be driving with anything open. Thanks in advance for the help. ~Isaac
the most common cause I seem to recall is the sensor in the rear hatch not pressing in enough. Spacing it so it presses further in solves many people problem from my memory banks. I'm sure theres a thread around somewhere with some pics or at least a write up of some form. I'll see what I can dig
edit:
http://www.nissanpathfinders.net/forum/topic/16098-wd21-rear-hatch-sensor/page__p__264336__hl__+flickering%20+light?do=findComment&comment=264336
http://www.nissanpathfinders.net/forum/topic/9688-door-light-on-when-door-is-closed-94-pathfinder/page__hl__%20flickering%20%20light
theres a couple older discussions on it that might give you some info :aok:
Edited by nunya
ad links
Mine doesn't have that sensor (not helpful lol) but it does have one in the tire carrier, which recently started acting up. I pulled it out, pulled the rubber cover off, and stuffed a little circle of rubber into it as a shim. Been working great since. :)
